Zigbee - ZHA show contact as switch
Hi Guys
I have a couple of zigbee contact door sensors that show up at switch ? Is there a reason that this happens ?
Hello there Vaughan Lundin,
There is a switch_as helper that can adjust that for you. The device is set by the interview and the quirks set for the device with zigbee, but you can change it with a helper.
Open your Home Assistant instance and show your helper entities.
