hello, I have a problem that all devices in zigbee2 mqtt no longer work. can you connect them again? where is the problem?
Have you tried to unplug/plug your zigbee adapter? Restart your HA host?
How did this happen? Were you doing something in particular?
What versions are you using ?
Zigbee2MQTT documentation :
Koenkk released this 3 days ago
Notes
- Home Assistant users: due to #7057 at least Home Assistant 2021.4.5 is required
Hello. I’ve already tried everything
doesn’t it update automatically?
Hello. I wanted to report back …
i have integrated xiaomi gw3 as a coordinator. since then everything has been ok. Only today the coordinator was suddenly no longer available. And I see there … in config there is a completely different user and password. how come all i did last night was programming in node-red.
