Hi.
I’ve just got slaes’s CC2652RB with zigbee2mqtt firmware (hopefully…). But I can’t get it working with HA. I have RPi4, tried both USB2 & USB3 ports and it behaves the same.
My config looks like this:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
user: '!secret mqtt_username'
password: '!secret mqtt_password'
serial:
port: /dev/ttyUSB0
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
and I end up with this in the log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[18:08:10] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[18:08:11] INFO: MQTT available, fetching server detail ...
[18:08:11] INFO: MQTT server settings not configured, trying to auto-discovering ...
[18:08:12] INFO: Configuring 'mqtt://core-mosquitto:1883' mqtt server
[18:08:12] INFO: Previous config file found, checking backup
[18:08:12] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[18:08:12] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[18:08:14] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Zigbee2MQTT:error 2021-12-01 18:09:38: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-12-01 18:09:38: Failed to start zigbee
Zigbee2MQTT:error 2021-12-01 18:09:38: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-12-01 18:09:38: Exiting...
Zigbee2MQTT:error 2021-12-01 18:09:38: Error: AREQ - ZDO - stateChangeInd after 60000ms
at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (internal/timers.js:557:17)
at processTimers (internal/timers.js:500:7)
The USB port should be correct:
[core-ssh ~]$ test -w /dls -l /dev/serial/by-id
total 0
lrwxrwxrwx 1 root root 13 Dec 1 17:20 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_21_4F_1D_16-if00-port0 -> ../../ttyUSB0
If I try changing the port in config as recommended by slaes to
serial:
port: /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_21_4F_1D_16-if00-port0
I end up with the same error.
[fix-attrs.d] done.
[18:21:40] INFO: Socat not enabled, marking service as down
[18:21:41] INFO: MQTT available, fetching server detail ...
[18:21:41] INFO: MQTT server settings not configured, trying to auto-discovering ...
[18:21:42] INFO: Configuring 'mqtt://core-mosquitto:1883' mqtt server
[18:21:42] INFO: Previous config file found, checking backup
[18:21:42] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[18:21:42] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] done.
[services.d] done.
[18:21:44] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:error 2021-12-01 18:22:35: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-12-01 18:22:35: Failed to start zigbee
Zigbee2MQTT:error 2021-12-01 18:22:35: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-12-01 18:22:35: Exiting...
Zigbee2MQTT:error 2021-12-01 18:22:35: Error: SRSP - SAPI - readConfiguration after 6000ms
