Zigbee2Mqtt 1.5.1.1 will not start
Again my whole appartement is dark and nothing works after the most recent update. Log says:
19-07-25 16:09:23 ERROR (MainThread) [hassio.addons.addon] Add-on 7ad98f9c_zigbee2mqtt have wrong options: Missing option availability_blacklist in advanced. Got {'data_path': '/share/zigbee2mqtt', 'devices': 'decices.yaml', 'groups': 'groups.yaml', 'homeassistant': True, 'permit_join': False, 'mqtt': {'base_topic': 'zigbee2mqtt', 'server': 'mqtt://192.168.0.222:1883', 'user': 'mqtt', 'password': 'XXXX'}, 'serial': {'port': '/dev/ttyACM0'}, 'advanced': {'pan_id': 6754, 'channel': 11, 'network_key': [1, 3, 5, 7, 9, 11, 13, 15, 0, 2, 4, 6, 8, 10, 12, 13]}, 'ban': [], 'whitelist': [], 'queue': {}}
Help…
What I did was copy the current configuration. Then reset the configuration to default and start copying over the settings from your old configuration.
Hope this helps.
Also if you have any device configuration it has to be in a separate file now. I also removed my config and let it default before copy/pasting the relevant parts.
Thanks a lot, that helped! A lot going on with this plugin the last days…
