blueprint:
name: Zigbee2MQTT - Tuya 1-Button Scene Switch
description: Automate your Tuya 1-Button Scene Switch via Zigbee2MQTT.
domain: automation
input:
switch:
name: Tuya 1-Button Scene Switch
description: Tuya 1-Button Scene Switch to use
selector:
entity:
integration: mqtt
domain: sensor
multiple: false
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 (lower-left) single press
default: []
selector:
action: {}
button_one_double_press:
name: Double Press - Button 1
description: Action to run on button 1 (lower-left) double press
default: []
selector:
action: {}
button_one_long_press:
name: Long Press - Button 1
description: Action to run on button 1 (lower-left) long press
default: []
selector:
action: {}
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input switch
attribute: action
- variables:
command: '{{ trigger.to_state.state }}'
- choose:
- conditions:
- '{{ command == ''single'' }}'
sequence: !input button_one_short_press
- conditions:
- '{{ command == ''double'' }}'
sequence: !input button_one_double_press
- conditions:
- '{{ command == ''hold'' }}'
sequence: !input button_one_long_press
Bleuprint doesn’t work. The line ‘attribute: action’ should be removed.
blueprint:
name: Zigbee2MQTT - Tuya 1-Button Scene Switch V01.2025
domain: automation
input:
switch:
selector:
device:
integration: mqttbutton_one_short_press: name: Single Press - Button 1 description: Action to run on button 1 (lower-left) single press default: [] selector: action: {} button_one_double_press: name: Double Press - Button 1 description: Action to run on button 1 (lower-left) double press default: [] selector: action: {} button_one_long_press: name: Long Press - Button 1 description: Action to run on button 1 (lower-left) long press default: [] selector: action: {}
- platform: device
device_id: !input switch
domain: mqtt
type: action
subtype: single- platform: device
domain: mqtt
type: action
subtype: double- platform: device
domain: mqtt
type: action
subtype: holdaction:
- variables:
command: ‘{{ trigger.payload }}’- choose:
- conditions:
- ‘{{ command == ‘‘single’’ }}’
sequence: !input button_one_short_press- conditions:
- ‘{{ command == ‘‘double’’ }}’
sequence: !input button_one_double_press- conditions:
- ‘{{ command == ‘‘hold’’ }}’
