kwatt
(Kenneth Watt)
January 4, 2025, 1:07pm
21
I sussed that and another error so it is now:
homeassistant:
enabled: true
advanced:
network_key:
- 116
- 96
- 201
- 167
- 99
- 168
- 147
- 53
- 228
- 247
- 32
- 178
- 20
- 205
- 156
- 210
pan_id: 2108
ext_pan_id:
- 161
- 35
- 112
- 39
- 164
- 70
- 52
- 249
serial:
port: /dev/ttyUSB1
adapter: zstack
homeassistant_legacy_entity_attributes: false
homeassistant_legacy_triggers: false
legacy_api: false
legacy_availability_payload: false
legacy: false
But I get the same error
kwatt
(Kenneth Watt)
January 4, 2025, 1:16pm
22
It was ember and worked preiously set to that but if I use that then I get this error:
tarting Zigbee2MQTT without watchdog.
[2025-01-04 13:15:02] info: z2m: Logging to console, file (filename: log.log)
[2025-01-04 13:15:02] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-04 13:15:02] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-04 13:15:02] info: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB1","manufacturer":"Nabu Casa","serialNumber":"6aca14c4533aef11a3352b1455516304","pnpId":"usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_6aca14c4533aef11a3352b1455516304-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: 2
[2025-01-04 13:15:02] info: zh:ember: Using default stack config.
[2025-01-04 13:15:03] info: zh:ember: ======== Ember Adapter Starting ========
[2025-01-04 13:15:03] info: zh:ember:ezsp: ======== EZSP starting ========
[2025-01-04 13:15:03] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-04 13:15:03] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-01-04 13:15:03] info: zh:ember:uart:ash: Serial port opened
[2025-01-04 13:15:03] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-01-04 13:15:04] info: zh:ember:uart:ash: ======== ASH connected ========
[2025-01-04 13:15:04] info: zh:ember:uart:ash: ======== ASH started ========
[2025-01-04 13:15:04] info: zh:ember:ezsp: ======== EZSP started ========
[2025-01-04 13:15:04] error: z2m: Error while starting zigbee-herdsman
[2025-01-04 13:15:04] error: z2m: Failed to start zigbee-herdsman
[2025-01-04 13:15:04] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-04 13:15:04] error: z2m: Exiting...
[2025-01-04 13:15:04] error: z2m: Error: Adapter EZSP protocol version (9) is not supported by Host [13-16].
at EmberAdapter.emberVersion (/app/node_modules/.pnpm/[email protected] /node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1403:19)
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected] /node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:674:9)
at EmberAdapter.start (/app/node_modules/.pnpm/[email protected] /node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1533:24)
at Controller.start (/app/node_modules/.pnpm/[email protected] /node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:142:13)
at start (/app/index.js:161:5)
Vlad
(Vladislav)
January 4, 2025, 1:18pm
23
Still you have wrong adapter
kwatt
(Kenneth Watt)
January 4, 2025, 1:21pm
24
I understand that but cannot work out why as it was ember and set to that I get the error above.
Set to zstack I get the error previous to that.
Itâs a Nabu Casa ZBT-1 I am using.
Vlad
(Vladislav)
January 4, 2025, 1:30pm
26
Home Assistant Connect ZBT-1
Model No. NC-ZBT-9710
Radio Chipset Silicon Labs Multiprotocol EFR32MG21
Based on specification itâs Silicon Labs
EmberZNet adapters (Silicon Labs)
kwatt
(Kenneth Watt)
January 4, 2025, 1:38pm
28
Perfect, many, many thanks as that solved it along with a restart.
For anyone that gets the same or similar error, what I did was put this at the top of the Z2M config:
serial:
port: #your apapter port info from hardware>connect
adapter: ezsp
legacy_api: false
legacy: false
And in the UI of MQTT add-on>config this:
serial:
adapter: ezsp
Once that was done and HA restarted all came back as normal with no issues I can see.
Thanks again guys, appreciate the help.
tom_l
January 4, 2025, 1:53pm
29
Whatâs interesting is that adapter option isnât listed in the z2m documentation. https://www.zigbee2mqtt.io/guide/configuration/adapter-settings.html
# Adapter type, allowed values: `zstack`, `ember`, `deconz`, `zigate` or `zboss`
I found it here: Home Assistant Connect ZBT-1
kwatt
(Kenneth Watt)
January 4, 2025, 2:11pm
30
Yeah, I noticed that as well and thought it odd. I wasnât sure if the ember and ezsp were the same thing or not a Iâm really not familiar enough to think any differently.
But, itâs all working fine now and I cannot find any errors anywhere using ezsp as the adapter.
still not working with me, I restored to previous version, and it work normally.
123
(Taras)
January 4, 2025, 8:51pm
32
FWIW, ezsp
was deprecated in favor of ember
(several months ago).
Reference
The second TIP box here:
kwatt
(Kenneth Watt)
January 4, 2025, 10:28pm
33
Yet when I used ember it didnt work, used ezsp and it does. Seems very odd.
123
(Taras)
January 4, 2025, 10:41pm
34
Can you confirm there were no other factors during the test that would have affected the result?
tom_l
January 4, 2025, 10:49pm
35
It seems pretty cut and dry from Kenâs posts above.
Which leads to either:
The dongle needs a firmware update , or
Thereâs a bug that needs reporting.
kwatt
(Kenneth Watt)
January 4, 2025, 10:50pm
36
No, none.
All I changed was the adaptor and nothing else, when I changed it from zstack or ember to ezsp it just sparked to life and worked.
(Taras)
January 4, 2025, 10:53pm
37
You may wish to report it as a bug in Zigbee2MQTTâs Github repository. If the coordinator hardware is from Silicon Labs, it should work with ember
kwatt
(Kenneth Watt)
January 4, 2025, 11:01pm
38
I did look at the firmware update but, following the advice on that page I thought it best to follow the recommendation not to do that, apart from which, updating firmware always makes me jittery unless thereâs good reasons to do that.
If Nabu Casa update it and the adapter needs changed to being ember thatâs fine, itâs no big deal to sort that out as long as people know to do it.
What irked me a bit, though itâs really nobodyâs fault, is that ezsp wasnât even listed or so much as mentioned and yet, it appears to be whatâs needed in this instance. Causing me to be bugging al you guys about it when it should have been easily sorted by myself.
tom_l
January 4, 2025, 11:06pm
39
Looks like this is a similar enough issue: EZSP to EMBER: TRADFRI E1745 unresponsive ¡ Issue #25283 ¡ Koenkk/zigbee2mqtt ¡ GitHub
Post your error message when you used adapter: ember
then note that it only works with the depreciated ezsp
option.
kwatt
(Kenneth Watt)
January 4, 2025, 11:12pm
40
No problem, I have done that.
tom_l
41
On second thought it might be best to create a new issue.
