Zigbee2MQTT 2.0 IKEA TRADFRI 5-Button Remote Actions
This blueprint allows you to more easily assign custom actions to your IKEA TRADFIR 5-button remote with the Zigbee2MQTT 2.0 update and its breaking changes. It does not use of any legacy features of Zigbee2MQTT and allows you to freely assign any action(s) to the buttons and their long-presses.
It’s similar to this blueprint and other blueprints variants for this remote, but uses the MQTT device itself instead of a sensor entity, because the entity is no longer exposed by Zigbee2MQTT 2.0 by default.
Blueprint
:link: GitHub Source Code
Preview
Happy automating!
Thank you for the blueprint.
One question: How can you specify a steady brightness increase of the lightbulb wenn holding the brightness up button? I can see, that there is a dedicated trigger for this but what is the correct action definition?
Thank you! This is really great.
I’m interested in an solution for this (dimming by holding) as well.
The blueprint is really a good successor to the current “action-problem”. thanks
Or to gradually change the colour of an RGB light?
Is there any way to add double click options? And centre button long press?
