I found now that some Zigbee bulbs are available in the frontend, but specfic models are not.
For me that’s all of my light bulbs from Tuya with model TS0505B_1_1
Manufacturer: _TZ3210_mja6r5ix
And I have many of that
Maybe here’s a problem in Z2M logging (Range Error):
[2025-03-02 11:19:45] e[34mdebuge[39m: z2m: Received Zigbee message from 'Eethoek', type 'raw', cluster 'lightingColorCtrl', data '{"data":[8,132,10,9,240,72,0],"type":"Buffer"}' from endpoint 1 with groupID 0
[2025-03-02 11:19:45] e[34mdebuge[39m: z2m: No converter available for 'TS0505B_1_1' with cluster 'lightingColorCtrl' and type 'raw' and data '{"data":[8,132,10,9,240,72,0],"type":"Buffer"}'
[2025-03-02 11:19:46] e[34mdebuge[39m: zh:zstack:unpi:parser: <-- [254,27,68,129,0,0,0,3,145,240,1,1,0,51,0,124,18,215,0,0,7,8,133,10,9,240,72,0,145,240,29,123]
[2025-03-02 11:19:46] e[34mdebuge[39m: zh:zstack:unpi:parser: --- parseNext [254,27,68,129,0,0,0,3,145,240,1,1,0,51,0,124,18,215,0,0,7,8,133,10,9,240,72,0,145,240,29,123]
[2025-03-02 11:19:46] e[34mdebuge[39m: zh:zstack:unpi:parser: --> parsed 27 - 2 - 4 - 129 - [0,0,0,3,145,240,1,1,0,51,0,124,18,215,0,0,7,8,133,10,9,240,72,0,145,240,29] - 123
[2025-03-02 11:19:46] e[34mdebuge[39m: zh:zstack:znp: <-- AREQ: AF - incomingMsg - {"groupid":0,"clusterid":768,"srcaddr":61585,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":51,"securityuse":0,"timestamp":14094972,"transseqnumber":0,"len":7,"data":{"type":"Buffer","data":[8,133,10,9,240,72,0]}}
[2025-03-02 11:19:46] e[34mdebuge[39m: zh:controller: Failed to parse frame: RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 5. Received 7
[2025-03-02 11:19:46] e[34mdebuge[39m: zh:controller: Received payload: clusterID=768, address=61585, groupID=0, endpoint=1, destinationEndpoint=1, wasBroadcast=false, linkQuality=51, frame=undefined
