Hello, can someone help me, I have the following problem.
zigbee2mqtt instaliert and all configurations made but does not work, I get the following error message. ‘502 Bad Gateway’
I’ve been trying for three days, I can’t get it going.
zigbee2mqtt setting:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
user: mqtt
password: *****
server: 'mqtt://core-mosquitto:1883'
serial:
port: >-
/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019387099-if00
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: 'pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
options: '-d -d'
log: false
zigbee2mqtt log file:
Zigbee2MQTT:error 2021-05-11 22:45:58: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-05-11 22:45:58: Failed to start zigbee
Zigbee2MQTT:error 2021-05-11 22:45:58: Check https://www.zigbee2mqtt.io/information/FAQ.html#help-zigbee2mqtt-fails-to-start for possible solutions
Zigbee2MQTT:error 2021-05-11 22:45:58: Exiting...
Zigbee2MQTT:error 2021-05-11 22:45:58: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
at Generator.throw (<anonymous>)
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-05-11T20_45_58_819Z-debug.log
[22:45:59] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start /app
> node index.js
Supervisor log file:
21-05-11 20:37:00 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.3:8099 ssl:default [Connect call failed ('172.30.33.3', 8099)]
21-05-11 20:37:04 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.3:8099 ssl:default [Connect call failed ('172.30.33.3', 8099)]
21-05-11 20:38:05 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.3:8099 ssl:default [Connect call failed ('172.30.33.3', 8099)]
21-05-11 20:39:07 INFO (SyncWorker_2) [supervisor.docker.interface] Stopping addon_486e6e9b_zigbee2mqtt application
21-05-11 20:39:11 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_486e6e9b_zigbee2mqtt application
21-05-11 20:39:13 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-amd64 with version 1.18.3-1
21-05-11 20:42:58 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.3:8099 ssl:default [Connect call failed ('172.30.33.3', 8099)]
Mosquitto broker setting
logins:
- username: mqtt
password: *****
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
Mosquitto broker log file:
[22:32:52] INFO: Setup mosquitto configuration
[22:32:52] WARNING: SSL not enabled - No valid certs found!
[22:32:52] INFO: Found local users inside config
[22:32:53] INFO: Initialize Home Assistant Add-on services
[22:32:53] INFO: Initialize Home Assistant discovery
[22:32:53] INFO: Start Mosquitto daemon
1620765173: mosquitto version 1.6.3 starting
1620765173: Config loaded from /etc/mosquitto.conf.
1620765173: Loading plugin: /usr/share/mosquitto/auth-plug.so
1620765173: |-- *** auth-plug: startup
1620765173: ├── Username/password checking enabled.
1620765173: ├── TLS-PSK checking enabled.
1620765173: └── Extended authentication not enabled.
1620765173: Opening ipv4 listen socket on port 1883.
1620765173: Opening ipv6 listen socket on port 1883.
1620765173: Opening websockets listen socket on port 1884.
1620765173: Warning: Mosquitto should not be run as root/administrator.
1620765204: New connection from 172.30.32.1 on port 1883.
[22:33:26] INFO: [INFO] found mqtt on local database
1620765206: New client connected from 172.30.32.1 as 3n2W185B03kjO7yT9ne9z9 (p2, c1, k60, u'mqtt').
1620765231: New connection from 192.168.178.22 on port 1883.
1620765231: New client connected from 192.168.178.22 as DVES_008112 (p2, c1, k30, u'mqtt').
System:
