Hi community,
I’m new at this whole smart home topic. I use my raspberry pi 2B with home assistant on it. It work so far but I’m not able to open the zigbee2mqtt frontend to add my devices.
Maybe one of you have an idea what I did wrong.
Thank you in advance
Cheers
Marcel
nickrout
(Nick Rout)
May 12, 2022, 7:57am
4
The log file tells you a page to check, have you?
Yes I checked the page. But I didn’t found a solution.
nickrout
(Nick Rout)
May 12, 2022, 8:19am
6
You have adapter: deconz
- that is not the recommended.
Tinkerer
(aka DubhAd on GitHub)
May 12, 2022, 8:20am
7
It is if you have any of the ConBee/RaspBee range though, see here
nickrout
(Nick Rout)
May 12, 2022, 8:26am
8
The docs say
# Optional: adapter type, not needed unless you are experiencing problems (default: shown below, options: zstack, deconz, ezsp)
adapter: null
So default is null, and only change if experiencing problems.
https://www.zigbee2mqtt.io/guide/configuration/adapter-settings.html
So a little confusing.
Thanks a lot for the fast answers!
I have the Conbee II stick.
I try to rewrite the configuration. Maybe it works.
