version 2022:6 trying to set it up and I get the above error.
http://192.168.0.144:8123/45df7312_zigbee2mqtt/dashboard
My config is,
base_topic: zigbeezmqtt
user: mqtt_user
password: xxxxxx
server: mqtt://192.168.0.144:1883
serial:
port: /dev/ttyUSB0
This seems to be a very common problem
at processTicksAndRejections (node:internal/process/task_queues:83:21)
[19:14:44] INFO: Handing over control to Zigbee2mqtt Core …
[email protected] start
node index.js
Zigbee2MQTT:info 2022-06-20 19:14:48: Logging to console and directory: ‘/config/zigbee2mqtt/log/2022-06-20.19-14-48’ filename: log.txt
Zigbee2MQTT:info 2022-06-20 19:14:48: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-20 19:14:48: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:error 2022-06-20 19:14:48: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-06-20 19:14:48: Failed to start zigbee
Zigbee2MQTT:error 2022-06-20 19:14:48: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2022-06-20 19:14:48: Exiting…
Zigbee2MQTT:error 2022-06-20 19:14:48: Error: spawn udevadm ENOENT
at Process.ChildProcess._handle.onexit (node:internal/child_process:283:19)
at onErrorNT (node:internal/child_process:478:16)
[19:14:49] INFO: Handing over control to Zigbee2mqtt Core …
node index.js
Zigbee2MQTT:info 2022-06-20 19:14:53: Logging to console and directory: ‘/config/zigbee2mqtt/log/2022-06-20.19-14-53’ filename: log.txt
Zigbee2MQTT:info 2022-06-20 19:14:53: Starting Zigbee2MQTT version 1.25.2 (commit #unknown)
Zigbee2MQTT:info 2022-06-20 19:14:53: Starting zigbee-herdsman (0.14.34)
Zigbee2MQTT:error 2022-06-20 19:14:53: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-06-20 19:14:53: Failed to start zigbee
xxx
Zigbee2MQTT:error 2022-06-20 19:14:53: Exiting…
Zigbee2MQTT:error 2022-06-20 19:14:53: Error: spawn udevadm ENOENT
[19:14:54] INFO: Handing over control to Zigbee2mqtt Core .
