I’m having the same issue.
I have a SONOFF dongle as well and I was trying to fix by repairing a couple of LED lamps (HG06106A).
Logs from zigbee2mqtt:
�Zigbee2MQTT:info 2023-09-25 10:33:43: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Livarno Lux GU10 spot RGB","exposes":[{"features":[{"access":7,"description":"On/off state of this light","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"Brightness of this light","label":"Brightness","name":"brightness","property":"brightness","type":"numeric","value_max":254,"value_min":0},{"access":7,"description":"Color temperature of this light","label":"Color temp","name":"color_temp","presets":[{"description":"Coolest temperature supported","name":"coolest","value":150},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":500}],"property":"color_temp","type":"numeric","unit":"mired","value_max":500,"value_min":150},{"access":7,"description":"Color of this light in the CIE 1931 color space (x/y)","features":[{"access":7,"label":"X","name":"x","property":"x","type":"numeric"},{"access":7,"label":"Y","name":"y","property":"y","type":"numeric"}],"label":"Color (X/Y)","name":"color_xy","property":"color","type":"composite"}],"type":"light"},{"access":2,"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","label":"Effect","name":"effect","property":"effect","type":"enum","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"]},{"access":3,"description":"Do not disturb mode, when enabled this function will keep the light OFF after a power outage","label":"Do not disturb","name":"do_not_disturb","property":"do_not_disturb","type":"binary","value_off":false,"value_on":true},{"access":3,"description":"Power on behavior state","label":"Color power on behavior","name":"color_power_on_behavior","property":"color_power_on_behavior","type":"enum","values":["initial","previous","cutomized"]},{"access":1,"description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"HG06106A","options":[{"access":2,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","label":"Transition","name":"transition","property":"transition","type":"numeric","value_min":0},{"access":2,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","label":"Color sync","name":"color_sync","property":"color_sync","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":false,"vendor":"Lidl"},"friendly_name":"0x842e14fffe3b752f","ieee_address":"0x842e14fffe3b752f","status":"successful","supported":true},"type":"device_interview"}'
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'homeassistant/light/0x842e14fffe3b752f/light/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"brightness":true,"brightness_scale":254,"color_mode":true,"command_topic":"zigbee2mqtt/Color Light 9a/set","device":{"identifiers":["zigbee2mqtt_0x842e14fffe3b752f"],"manufacturer":"Lidl","model":"Livarno Lux GU10 spot RGB (HG06106A)","name":"Color Light 9a"},"effect":true,"effect_list":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"max_mireds":500,"min_mireds":150,"name":null,"object_id":"color_light_9a","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"schema":"json","state_topic":"zigbee2mqtt/Color Light 9a","supported_color_modes":["xy","color_temp"],"unique_id":"0x842e14fffe3b752f_light_zigbee2mqtt"}'
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'homeassistant/select/0x842e14fffe3b752f/effect/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Color Light 9a/set/effect","device":{"identifiers":["zigbee2mqtt_0x842e14fffe3b752f"],"manufacturer":"Lidl","model":"Livarno Lux GU10 spot RGB (HG06106A)","name":"Color Light 9a"},"enabled_by_default":false,"icon":"mdi:palette","name":"Effect","object_id":"color_light_9a_effect","options":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"unique_id":"0x842e14fffe3b752f_effect_zigbee2mqtt"}'
Zigbee2MQTT:info 2023-09-25 10:33:42: Successfully interviewed '0x842e14fffe3b752f', device has successfully been paired
Zigbee2MQTT:info 2023-09-25 10:33:42: Device '0x842e14fffe3b752f' is supported, identified as: Lidl Livarno Lux GU10 spot RGB (HG06106A)
Zigbee2MQTT:info 2023-09-25 10:33:43: Configuring '0x842e14fffe3b752f'
Zigbee2MQTT:info 2023-09-25 10:33:43: Successfully configured '0x842e14fffe3b752f'
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'zigbee2mqtt/0x842e14fffe3b752f', payload ''
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'homeassistant/switch/0x842e14fffe3b752f/switch_do_not_disturb/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Color Light 9a/set/do_not_disturb","device":{"identifiers":["zigbee2mqtt_0x842e14fffe3b752f"],"manufacturer":"Lidl","model":"Livarno Lux GU10 spot RGB (HG06106A)","name":"Color Light 9a"},"name":"Do not disturb","object_id":"color_light_9a_do_not_disturb","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/Color Light 9a","unique_id":"0x842e14fffe3b752f_switch_do_not_disturb_zigbee2mqtt","value_template":"{% if value_json.do_not_disturb %} true {% else %} false {% endif %}"}'
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'homeassistant/sensor/0x842e14fffe3b752f/color_power_on_behavior/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x842e14fffe3b752f"],"manufacturer":"Lidl","model":"Livarno Lux GU10 spot RGB (HG06106A)","name":"Color Light 9a"},"enabled_by_default":false,"entity_category":"config","icon":"mdi:palette","name":"Color power on behavior","object_id":"color_light_9a_color_power_on_behavior","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Color Light 9a","unique_id":"0x842e14fffe3b752f_color_power_on_behavior_zigbee2mqtt","value_template":"{{ value_json.color_power_on_behavior }}"}'
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'homeassistant/select/0x842e14fffe3b752f/color_power_on_behavior/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/Color Light 9a/set/color_power_on_behavior","device":{"identifiers":["zigbee2mqtt_0x842e14fffe3b752f"],"manufacturer":"Lidl","model":"Livarno Lux GU10 spot RGB (HG06106A)","name":"Color Light 9a"},"entity_category":"config","icon":"mdi:palette","name":"Color power on behavior","object_id":"color_light_9a_color_power_on_behavior","options":["initial","previous","cutomized"],"origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Color Light 9a","unique_id":"0x842e14fffe3b752f_color_power_on_behavior_zigbee2mqtt","value_template":"{{ value_json.color_power_on_behavior }}"}'
Zigbee2MQTT:info 2023-09-25 10:34:08: MQTT publish: topic 'homeassistant/sensor/0x842e14fffe3b752f/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x842e14fffe3b752f"],"manufacturer":"Lidl","model":"Livarno Lux GU10 spot RGB (HG06106A)","name":"Color Light 9a"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"color_light_9a_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Color Light 9a","unique_id":"0x842e14fffe3b752f_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
I can control the lamps if I manually publish the correct topics and payloads as described in the specification, however from the homeassitant I can only see the “do not disturb” switch, which does not do much.
