So i have installed on a proxmox vm a HASSIO.
I bought a SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2.
My HA seens the stick i tried to install Zigbee2MQTT add-on so i can manage my IKEA lightbulb but when i start the MQTT it gives an error:
Confs
Zigbee2MQTT YAML
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://localhost:1883
user: my_user
password: "my_password"
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007192042-if00
Broker yaml:
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
(on default, aswell the mqtt integration) zha is deleted
i get this error:
[23:17:14] INFO: Preparing to start...
[23:17:14] INFO: Socat not enabled
[23:17:14] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-03-22 23:17:16: Logging to console and directory: '/config/zigbee2mqtt/log/2024-03-22.23-17-15' filename: log.txt
Zigbee2MQTT:info 2024-03-22 23:17:16: Starting Zigbee2MQTT version 1.36.0 (commit #unknown)
Zigbee2MQTT:info 2024-03-22 23:17:16: Starting zigbee-herdsman (0.35.1)
Zigbee2MQTT:info 2024-03-22 23:17:20: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2024-03-22 23:17:20: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
Zigbee2MQTT:info 2024-03-22 23:17:20: Currently 0 devices are joined:
Zigbee2MQTT:info 2024-03-22 23:17:20: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-03-22 23:17:20: Connecting to MQTT server at mqtt://localhost:1883
Zigbee2MQTT:error 2024-03-22 23:17:20: MQTT error: connect ECONNREFUSED 127.0.0.1:1883
Zigbee2MQTT:error 2024-03-22 23:17:20: MQTT failed to connect, exiting...
Zigbee2MQTT:info 2024-03-22 23:17:20: Stopping zigbee-herdsman...
Zigbee2MQTT:info 2024-03-22 23:17:21: Stopped zigbee-herdsman
note i havent masked the password it i my actual yaml idk what user/pass it is asking i guess thats a default because i see it everywhere
