Am trying to get zigbee2mqtt add-on to start and having no luck.
Log is below. I use a TubesZB Poe coordinator which was working and from its log HA is connecting but the add on seems to just hang and I get 502 bad gateway error when trying to view the GUI. Assuming it isn’t starting.
Appreciate some assistance from the Brains trust.
Log below:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] socat.sh: executing…
[22:14:50] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing…
[22:14:50] WARNING: No devices.js file found in data path, starting with default devices.js
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:14:50] INFO: Zigbee Herdsman debug logging enabled
[22:14:50] INFO: Handing over control to Zigbee2mqtt Core …
[email protected] start
node index.js
Zigbee2MQTT:info 2022-05-13 22:14:52: Logging to console and directory: ‘/config/zigbee2mqtt/log/2022-05-13.22-14-51’ filename: log.txt
Zigbee2MQTT:info 2022-05-13 22:14:52: Starting Zigbee2MQTT version 1.25.1 (commit #unknown)
Zigbee2MQTT:info 2022-05-13 22:14:52: Starting zigbee-herdsman (0.14.27)
2022-05-13T12:14:52.480Z zigbee-herdsman:controller:log Starting with options ‘{“network”:{“networkKeyDistribute”:false,“networkKey”:[19,35,78,1,23,10,21,45,67,2,59,6,81,91,21,39],“panID”:6754,“extendedPanID”:[221,221,221,221,221,221,221,221],“channelList”:[11]},“serialPort”:{“path”:“tcp://192.168.1.151:6638”,“adapter”:“ezsp”},“databasePath”:“/config/zigbee2mqtt/database.db”,“databaseBackupPath”:“/config/zigbee2mqtt/database.db.backup”,“backupPath”:“/config/zigbee2mqtt/coordinator_backup.json”,“adapter”:{“disableLED”:false,“concurrent”:null,“delay”:null}}’
2022-05-13T12:14:52.482Z zigbee-herdsman:adapter:ezsp:uart Opening TCP socket with 192.168.1.151:6638
2022-05-13T12:14:52.486Z zigbee-herdsman:adapter:ezsp:uart Socket connected
2022-05-13T12:14:52.487Z zigbee-herdsman:adapter:ezsp:uart Socket ready
2022-05-13T12:14:52.487Z zigbee-herdsman:adapter:ezsp:uart uart reseting
2022-05-13T12:14:52.487Z zigbee-herdsman:adapter:ezsp:uart Write reset
2022-05-13T12:14:52.488Z zigbee-herdsman:adapter:ezsp:uart → [1ac038bc7e] [26,192,56,188,126]
