My Zigbee2MQTT stopped and wont restart. I get
error 502- Bad Gateway
I reinstalled the add-on and get the same results.
Looking at the add-on log, I see this:
READ THIS CAREFULLY
Refusing to start because configuration is not valid, found the following errors:
- MQTT retention requires protocol version 5
If you don't know how to solve this, read https://www.zigbee2mqtt.io/guide/configuration
But there is nothing in the configuration guide about “protocol version 5”
I restored a backup from two days ago when I knew Zigbee devices were working, and got the same results.
I also tried using a different MQTT broker- same results.
Any tips would be appreciated.
