Zigbee2MQTT add-on won’t stay running unless socat block exists (even when disabled)
I’m posting this to save other users a lot of time — this issue looks like bad hardware, firmware, or USB problems, but it isn’t.
Symptoms
  • Zigbee2MQTT logs show:
    • Adapter detected
    • Coordinator starts
    • Backup written
  • Home Assistant UI:
    • Add-on flips back to :arrow_forward: Start
    • CPU/RAM briefly appears, then disappears
    • Looks like it “isn’t running”
  • Config edits:
    • Some keys are silently removed on Save
    • No clear validation error shown
This led me (wrongly) to suspect:
  • Bad dongle
  • Firmware incompatibility
  • ZBT-2 vs Sonoff issue
  • Mosquitto problem
Root cause
The HA Zigbee2MQTT add-on requires a socat: block to exist, even when socat is disabled.
If socat: is missing entirely:
  • Config saves
  • Zigbee2MQTT starts briefly
  • Then exits cleanly (not a crash)
  • HA UI flips back to :arrow_forward: Start
Because it’s a clean shutdown, it’s very misleading.
Working minimal config
This works reliably:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr
  options: "-d -d"
  log: false
mqtt:
  server: mqtt://core-mosquitto
serial:
  port: /dev/ttyUSB0
  adapter: zstack
  baudrate: 115200
Once this was in place:
  • Add-on stayed running
  • UI state matched reality
  • Both ZBT-2 and Sonoff Zigbee 3.0 USB Dongle Plus worked fine
Environment
  • Home Assistant Green
  • HA OS
  • Zigbee2MQTT add-on 2.7.x
  • Mosquitto add-on (default config)
  • Dongles tested:
    • Nabu Casa ZBT-2
    • Sonoff Zigbee 3.0 USB Dongle Plus
Why posting this
The failure mode looks exactly like:
  • bad hardware
  • firmware mismatch
  • USB instability
It’s actually a config schema / validation gotcha.
Hopefully this saves someone else a weekend :slightly_smiling_face:
