Hi
Installed zigbee2mqtt add-on
Flashed my CC2531 Release 1.18.1 · Koenkk/zigbee2mqtt · GitHub
usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE8B131
Can see it on my PI when I add it
21-12-16 16:24:01 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bus/usb/001/012 - None
21-12-16 16:24:01 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/ttyACM0 - /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE8B131-if00
Had MQTT already installed and working
Added two door sensors - [MCCGQ01LM] and I can see this open and close
So all good…
The bit I cant do if adding the integration /config/integrations/ZHA
Select serial port for Zigbee radio
Serial Device Path used - /dev/ttyACM0 - /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B000BE8B131-if00
Radio Type - Pick a type of your Zigbee radio
Used - ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2
Settings Enter port specific settings leaving at default which is
115200
data flow control (not S/W or H/W)
as per Zigbee Home Automation - Home Assistant
Error is failed to connect, sensors are working and reporting to MQTT just this integration is failing.
Tried manual, rechecked device etc bit lost on the next step?
Any thoughts?
