Zigbee2MQTT addon cleanup
I’m in a house cleaning phase of my HASS running on rpi 4.
Currently running 2024016.
At some stage, I installed the Zigbee2MQTT addon.
Now no more in use.
I uninstalled the addon through HA UI.
However, according to supervisor log file, I still find the addon loaded.
I still have a directory zigbee2mqtt under HA main directory. Is it the reason ?
Can I simply remove this directory ?
Thanks, B.
24-02-05 13:07:09 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-05 13:07:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - einschmidt/hassio-addons: Home Assistant addons repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - haberda/hassio_addons: hopefully useful hassio addons repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - zigbee2mqtt/hassio-zigbee2mqtt: Official Zigbee2MQTT Home Assistant add-on repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
24-02-05 13:07:11 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-05 13:07:15 INFO (MainThread) [supervisor.store] Loading add-ons from store: 89 all - 0 new - 0 remove
24-02-05 13:07:17 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
24-02-05 13:07:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
Yes, if you have removed the addon.
You will also need to remove any retained discovery messages in your mqtt broker.
