Trying to install z2m addon.
Configuration fails with below error
Zigbee2MQTT:error 2023-07-28 19:39:40: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
The output of
ls -l /dev/serial/by-id/*
is
lrwxrwxrwx 1 root root 13 Jul 28 18:59 /dev/serial/by-id/usb-I TEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220815205657-if00 -> ../../ttyACM0
My z2m configuration reads
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt: {}
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220815205657-if00
yet the startup fails with the error above.
I tried installing using port: /dev/ttyACM0 too, but that also fails with the same error.
On the other hand, if I install in docker using
version: '3'
services:
zigbee2mqtt:
image: koenkk/zigbee2mqtt
container_name: zigbee2mqtt
restart: always
network_mode: host
environment:
- TZ=Asia/Kolkata
devices:
- /dev/ttyACM0:/dev/ttyACM0
ports:
- 8080:8080/tcp
volumes:
- /storage/.kodi/userdata/docker/Z2M:/app/data
- /run/udev:/run/udev:ro
then it works just fine.
Can anyone figure whats wrong with the addon config?
