Hi, not sure whats happened, around 11 hours ago now, Zigbee addon just stopped working, with the error:
[00:36:14] INFO: Preparing to start...
[00:36:14] INFO: Socat not enabled
[00:36:15] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2023-08-29 00:36:17: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info 2023-08-29 00:36:17: Logging to console and directory: '/config/zigbee2mqtt/log/2023-08-29.00-36-17' filename: log.txt
Zigbee2MQTT:debug 2023-08-29 00:36:17: Removing old log directory '/config/zigbee2mqtt/log/2023-08-29.00-17-21'
Zigbee2MQTT:info 2023-08-29 00:36:17: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-29 00:36:17: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:debug 2023-08-29 00:36:17: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"tcp://192.168.1.98:8888"}}'
Zigbee2MQTT:error 2023-08-29 00:36:17: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-08-29 00:36:17: Failed to start zigbee
Zigbee2MQTT:error 2023-08-29 00:36:17: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-08-29 00:36:17: Exiting...
Zigbee2MQTT:error 2023-08-29 00:36:17: Error: Error while opening socket
at Socket.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:198:24)
at Socket.emit (node:events:525:35)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
I have an Athom Zigbee Bridge running Tasmota and I can connect to that UI no issue, but suddenly HA cant seem to get the addon running. Iv removed it, reinstalled it, restored VM from backup, deleted the folder and started from scratch… but Im puzzled whats going on… Maybe the Athom has got a problem? Any one got any ideas?
