Hi, I have updated Zigbee2MQTT from 1.0.42-2 to 2.0.0-1.
The application stops after reading the usb adapter list.
[2025-01-05 15:17:36] info: z2m: Logging to console, file (filename: log.log)
[2025-01-05 15:17:36] debug: z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2025-01-05 15:17:36] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-05 15:17:36] debug: z2m: sd-notify loaded
[2025-01-05 15:17:36] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-05 15:17:36] debug: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":6754,\"extendedPanID\":[221,221,221,221,221,221,221,221],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/ttyACM0\",\"adapter\":\"deconz\"},\"adapter\":{\"disableLED\":false}}"'
[2025-01-05 15:17:37] debug: zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2599842","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2599842-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyACM1","manufacturer":"0658","pnpId":"usb-0658_0200-if00","vendorId":"0658","productId":"0200"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
Any help is appreciated here. I did not change anything to the configuration.yaml before updating and it was running perfectly before.
I have added the configuration.yaml
homeassistant:
enabled: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: addons
password: xxxxxxxxxxx
serial:
port: /dev/ttyACM0
adapter: deconz
frontend:
enabled: true
port: 8099
devices:
'0x0c4314fffed033f9':
friendly_name: Thermo keuken
description: Thermostaat kraan keuken
homeassistant:
optimistic: true
'0xf4b3b1fffea13edd':
friendly_name: Thermo serre radiator
description: Thermo knop radiator bij het serre raam
homeassistant:
name: Thermo Serre radiator
optimistic: true
'0xf4b3b1fffea1540f':
friendly_name: Thermo kamer Tim
description: Thermostaat kraan Tim
homeassistant:
optimistic: true
'0xf0d1b800001bde5c':
friendly_name: Buiten schakelaar LEDVANCE
description: Ledvance zigbee buiten schakelaar
homeassistant:
optimistic: true
'0xe0798dfffebbd8bd':
friendly_name: Carport relais
description: Relais schakelaar buitenlamp achter het huis okt 2023
'0xe0798dfffeb2acb7':
friendly_name: Relais buitenlamp voor
description: Relais buitenlamp voor geplaatst okt 2023
'0xa4c138165cb0f1ab':
friendly_name: Plug draadloos laadstat. Martien
description: in en uitschakelen van de draadloze oplader okt 2023
'0x086bd7fffe5d86fa':
friendly_name: Staande schemerlamp voetschakelaar
description: Voetschakelaar nov 2023
'0xa4c1383a8bf49ace':
friendly_name: Plugje wekker
description: Plugje wekker okt 2023
'0xa4c138d00d615b8e':
friendly_name: Kerstplug 4 (zigbee)
description: Zigbee kerstplug 4 in gebruik dec-2024
'0x04cf8cdf3c787200':
friendly_name: Lichtsensor
'0x54ef441000a11864':
friendly_name: Voordeur contact
description: Voordeur contact, geplaatst 39 mrt 2024
'0xbc026efffe440643':
friendly_name: Relais buitenlamp achter
description: Relais geplaatst 26 maart 2024 (HaShop.nl)
'0xe0798dfffee7e1f4':
friendly_name: Zigbee repeater
'0x040d84fffe5871f3':
friendly_name: Watersensor
'0x84fd27fffebaac02':
friendly_name: CO detector
'0xcc86ecfffe455ad4':
friendly_name: Rook detector 1 beneden
'0x5c0272fffec63d99':
friendly_name: Rook detector 2 boven
'0x847127fffea83a62':
friendly_name: Rookdetector 3 (ketel)
'0x847127fffead4801':
friendly_name: Rookdetector 4 (keuken)
'0x847127fffea1f794':
friendly_name: Rookdetector 5 (berging)
'0x54ef441000beef53':
friendly_name: deurcontact 2 (serre)
'0x54ef441000c344e5':
friendly_name: deurcontact 3 (achterdeur)
'0xa4c138204660f4d5':
friendly_name: Grondvochtigheid meter 1
advanced:
log_syslog:
app_name: Zigbee2MQTT
eol: /n
host: localhost
localhost: localhost
path: /dev/log
pid: process.pid
port: 514
protocol: udp4
type: '5424'
channel: 11
log_level: debug
version: 4
After restoring to 1.0.42 the log looks like this:
[2025-01-05 15:28:08] info: z2m: Logging to console, file (filename: log.log)
[2025-01-05 15:28:08] debug: z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2025-01-05 15:28:08] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2025-01-05 15:28:08] debug: z2m: sd-notify loaded
[2025-01-05 15:28:08] info: z2m: Starting zigbee-herdsman (2.1.9)
[2025-01-05 15:28:08] debug: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":6754,\"extendedPanID\":[221,221,221,221,221,221,221,221],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/ttyACM0\",\"adapter\":\"deconz\"},\"adapter\":{\"disableLED\":false}}"'
[2025-01-05 15:28:10] debug: zh:adapter: Path '/dev/ttyACM0' is valid for 'DeconzAdapter'
[2025-01-05 15:28:10] debug: zh:deconz:driver: Set delay to 0
[2025-01-05 15:28:10] debug: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/ttyACM0","adapter":"deconz"},"adapter":{"disableLED":false},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
