Zigbee2mqtt all devices disappeared
After a restart all of my previously working Zigbee devices disappeared. Tried restarts, reinstalls of Zigbee2mqtt. Desperately need some extra eyes to look into my logs:
Hardware: RPI4, CC2531, Ikea devices, PTVO switches etc.
My configuration:
data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://core-mosquitto'
  user: mosquit_user
  password: mosquito_password
serial:
  port: /dev/ttyACM0
advanced:
  log_level: debug
  pan_id: 6754
  channel: 15
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental:
  new_api: true
socat:
  enabled: false
  master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
  slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
  restartdelay: 1
  initialdelay: 1
  options: '-d -d'
  log: true
The error log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
./run.sh: line 17: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2020-10-06T10:12:19: PM2 log: Launching in no daemon mode
2020-10-06T10:12:19: PM2 log: App [npm:0] starting in -fork mode-
2020-10-06T10:12:20: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.15.0
> node index.js
Zigbee2MQTT:info  2020-10-06 10:12:23: Logging to console and directory: '/share/zigbee2mqtt/log/2020-10-06.10-12-23' filename: log.txt
Zigbee2MQTT:debug 2020-10-06 10:12:23: Removing old log directory '/share/zigbee2mqtt/log/2020-10-06.08-53-19'
Zigbee2MQTT:debug 2020-10-06 10:12:24: Loaded state from file /share/zigbee2mqtt/state.json
Zigbee2MQTT:info  2020-10-06 10:12:24: Starting Zigbee2MQTT version 1.15.0 (commit #1.15.0)
Zigbee2MQTT:info  2020-10-06 10:12:24: Starting zigbee-herdsman...
Zigbee2MQTT:debug 2020-10-06 10:12:24: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null},"backupPath":"/share/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/share/zigbee2mqtt/database.db.backup","databasePath":"/share/zigbee2mqtt/database.db","network":{"channelList":[15],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyACM0"}}'
Zigbee2MQTT:info  2020-10-06 10:12:26: zigbee-herdsman started
Zigbee2MQTT:info  2020-10-06 10:12:26: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"}'
Zigbee2MQTT:debug 2020-10-06 10:12:26: Zigbee network parameters: {"channel":15,"extendedPanID":"0xdddddddddddddddd","panID":6754}
Zigbee2MQTT:info  2020-10-06 10:12:26: Currently 0 devices are joined:
Zigbee2MQTT:warn  2020-10-06 10:12:26: `permit_join` set to  `true` in configuration.yaml.
Zigbee2MQTT:warn  2020-10-06 10:12:26: Allowing new devices to join.
Zigbee2MQTT:warn  2020-10-06 10:12:26: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info  2020-10-06 10:12:26: Zigbee: allowing new devices to join.
Zigbee2MQTT:info  2020-10-06 10:12:26: Started frontend on port 8099
Zigbee2MQTT:info  2020-10-06 10:12:26: Connecting to MQTT server at mqtt://core-mosquitto
Zigbee2MQTT:info  2020-10-06 10:12:27: Connected to MQTT server
Zigbee2MQTT:info  2020-10-06 10:12:28: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info  2020-10-06 10:12:28: MQTT publish: topic 'zigbee2mqtt/bridge/info', payload '{"commit":"1.15.0","config":{"advanced":{"adapter_concurrent":null,"availability_blacklist":[],"availability_blocklist":[],"availability_passlist":[],"availability_timeout":0,"availability_whitelist":[],"cache_state":true,"cache_state_persistent":true,"cache_state_send_on_startup":true,"channel":15,"elapsed":false,"ext_pan_id":[221,221,221,221,221,221,221,221],"homeassistant_discovery_topic":"homeassistant","homeassistant_legacy_triggers":true,"homeassistant_status_topic":"hass/status","last_seen":"disable","legacy_api":true,"log_directory":"/share/zigbee2mqtt/log/%TIMESTAMP%","log_file":"log.txt","log_level":"debug","log_output":["console","file"],"log_rotation":true,"log_syslog":{},"pan_id":6754,"report":false,"soft_reset_timeout":0,"timestamp_format":"YYYY-MM-DD HH:mm:ss"},"ban":[],"blocklist":[],"device_options":{},"devices":{"0x000d6ffffe343d9c":{"friendly_name":"0x000d6ffffe343d9c"},"0x00124b00094a81ae":{"friendly_name":"0x00124b00094a81ae"},"0x00124b00097331f3":{"friendly_name":"0x00124b00097331f3"},"0x00124b0009e004d5":{"friendly_name":"0x00124b0009e004d5"},"0x00124b000a54d665":{"friendly_name":"0x00124b000a54d665"},"0x00124b000c2c7e38":{"friendly_name":"0x00124b000c2c7e38"},"0x00124b000cccaec9":{"friendly_name":"0x00124b000cccaec9"},"0x00124b000dd71d33":{"friendly_name":"0x00124b000dd71d33"},"0x00124b000e95c57b":{"friendly_name":"0x00124b000e95c57b"},"0x00124b0011c4aa1d":{"friendly_name":"0x00124b0011c4aa1d"},"0x00124b001b7d9345":{"friendly_name":"0x00124b001b7d9345"},"0x00124b001c4bd33c":{"friendly_name":"0x00124b001c4bd33c"},"0x00124b001c4bd76d":{"friendly_name":"0x00124b001c4bd76d"},"0x00124b001d44d12b":{"friendly_name":"0x00124b001d44d12b"},"0x00124b001d44d31a":{"friendly_name":"0x00124b001d44d31a"},"0x00124b001d4514ad":{"friendly_name":"0x00124b001d4514ad"},"0x00124b001d452116":{"friendly_name":"0x00124b001d452116"},"0x00124b001d863d78":{"friendly_name":"0x00124b001d863d78"},"0x00158d00047c4cbf":{"friendly_name":"0x00158d00047c4cbf"},"0x00158d00049daf83":{"friendly_name":"0x00158d00049daf83"},"0x14b457fffe2e912e":{"friendly_name":"0x14b457fffe2e912e"},"0x14b457fffe5353fb":{"friendly_name":"0x14b457fffe5353fb"},"0x14b457fffe6d8926":{"friendly_name":"0x14b457fffe6d8926"},"0x14b457fffe7b8651":{"friendly_name":"0x14b457fffe7b8651"},"0x14b457fffe7f3d9f":{"friendly_name":"0x14b457fffe7f3d9f"},"0x680ae2fffe3f7f03":{"friendly_name":"0x680ae2fffe3f7f03"},"0x680ae2fffe4045dd":{"friendly_name":"0x680ae2fffe4045dd"},"0x680ae2fffe416dce":{"friendly_name":"0x680ae2fffe416dce"},"0x680ae2fffe423bd7":{"friendly_name":"0x680ae2fffe423bd7"},"0x680ae2fffef2827d":{"friendly_name":"0x680ae2fffef2827d"},"0xcccc0302010347c2":{"friendly_name":"0xcccc0302010347c2"},"0xcccc030201034a7c":{"friendly_name":"0xcccc030201034a7c"},"0xec1bbdfffe1ca214":{"friendly_name":"0xec1bbdfffe1ca214"},"0xec1bbdfffe2c1a13":{"friendly_name":"0xec1bbdfffe2c1a13"},"0xec1bbdfffe36260f":{"friendly_name":"0xec1bbdfffe36260f"}},"experimental":{"new_api":true,"output":"json"},"external_converters":[],"frontend":{"port":8099},"groups":{},"homeassistant":true,"map_options":{"graphviz":{"colors":{"fill":{"coordinator":"#e04e5d","enddevice":"#fff8ce","router":"#4ea3e0"},"font":{"coordinator":"#ffffff","enddevice":"#000000","router":"#ffffff"},"line":{"active":"#009900","inactive":"#994444"}}}},"mqtt":{"base_topic":"zigbee2mqtt","include_device_information":false,"password":"mosquito","server":"mqtt://core-mosquitto","user":"mosquito"},"passlist":[],"permit_join":true,"queue":{},"serial":{"disable_led":false,"port":"/dev/ttyACM0"},"whitelist":[]},"coordinator":{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"},"log_level":"debug","network":{"channel":15,"extended_pan_id":"0xdddddddddddddddd","pan_id":6754},"permit_join":true,"version":"1.15.0"}'
Zigbee2MQTT:info  2020-10-06 10:12:28: MQTT publish: topic 'zigbee2mqtt/bridge/devices', payload '[{"definition":null,"endpoints":{"1":{"bindings":[],"clusters":{"input":[],"output":[]}},"11":{"bindings":[],"clusters":{"input":["ssIasAce"],"output":["ssIasZone","ssIasWd"]}},"110":{"bindings":[],"clusters":{"input":[],"output":[]}},"12":{"bindings":[],"clusters":{"input":[],"output":[]}},"13":{"bindings":[],"clusters":{"input":["genOta"],"output":[]}},"2":{"bindings":[],"clusters":{"input":[],"output":[]}},"242":{"bindings":[],"clusters":{"input":[],"output":[]}},"3":{"bindings":[],"clusters":{"input":[],"output":[]}},"4":{"bindings":[],"clusters":{"input":[],"output":[]}},"47":{"bindings":[],"clusters":{"input":[],"output":[]}},"5":{"bindings":[],"clusters":{"input":[],"output":[]}},"6":{"bindings":[],"clusters":{"input":[],"output":[]}},"8":{"bindings":[],"clusters":{"input":[],"output":[]}}},"friendly_name":"Coordinator","ieee_address":"0x00124b0018e8847f","interview_completed":true,"interviewing":false,"network_address":0,"supported":false,"type":"Coordinator"}]'
Zigbee2MQTT:info  2020-10-06 10:12:28: MQTT publish: topic 'zigbee2mqtt/bridge/groups', payload '[]'
Zigbee2MQTT:info  2020-10-06 10:12:28: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"1.15.0","coordinator":{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"},"log_level":"debug","network":{"channel":15,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":true,"version":"1.15.0"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/B4D6C7_RL_1/config' with data '{"name":"Amplifier","cmd_t":"~cmnd/POWER1","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER1}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"B4D6C7_RL_1","device":{"identifiers":["B4D6C7"],"connections":[["mac","5C:CF:7F:B4:D6:C7"]]},"~":"Quad/"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/B4D6C7_RL_2/config' with data '{"name":"Tuner","cmd_t":"~cmnd/POWER2","stat_t":"~tele/STATE","val_tpl":"{{value_json.POWER2}}","pl_off":"OFF","pl_on":"ON","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"B4D6C7_RL_2","device":{"identifiers":["B4D6C7"],"connections":[["mac","5C:CF:7F:B4:D6:C7"]]},"~":"Quad/"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/3F0954_RL_1/config' with data '{"name":"Shed","stat_t":"Shed/tele/STATE","avty_t":"Shed/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"Shed/cmnd/POWER","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","uniq_id":"3F0954_RL_1","dev":{"ids":["3F0954"]}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/BD60E3_RL_1/config' with data '{"name":"TasmoTest","stat_t":"TasmoTest/tele/STATE","avty_t":"TasmoTest/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"TasmoTest/cmnd/POWER","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","uniq_id":"BD60E3_RL_1","dev":{"ids":["BD60E3"]}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/3EACDB_RL_1/config' with data '{"name":"Egg","stat_t":"Egg/tele/STATE","avty_t":"Egg/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"Egg/cmnd/POWER","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","uniq_id":"3EACDB_RL_1","dev":{"ids":["3EACDB"]}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/BD60E7_RL_1/config' with data '{"name":"Temp CV","stat_t":"Temperatures/tele/STATE","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"Temperatures/cmnd/POWER","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","uniq_id":"BD60E7_RL_1","dev":{"ids":["BD60E7"]}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/switch/BD7C88_RL_1/config' with data '{"name":"TV","stat_t":"TV/tele/STATE","avty_t":"TV/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"TV/cmnd/POWER","val_tpl":"{{value_json.POWER}}","pl_off":"OFF","pl_on":"ON","uniq_id":"BD7C88_RL_1","dev":{"ids":["BD7C88"]}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/B4D6C7_BTN_1/config' with data '{"name":"Amplifier Button1","stat_t":"~stat/BUTTON1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"B4D6C7_BTN_1","device":{"identifiers":["B4D6C7"],"connections":[["mac","5C:CF:7F:B4:D6:C7"]]},"~":"Quad/","value_template":"{{value_json.STATE}}","pl_on":"TOGGLE","off_delay":1}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/B4D6C7_SW_1/config' with data '{"name":"Amplifier Switch1","stat_t":"~stat/SWITCH1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"B4D6C7_SW_1","device":{"identifiers":["B4D6C7"],"connections":[["mac","5C:CF:7F:B4:D6:C7"]]},"~":"Quad/","value_template":"{%if is_state(entity_id,\"on\")-%}OFF{%-else-%}ON{%-endif%}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/B4D6C7_SW_2/config' with data '{"name":"Amplifier Switch2","stat_t":"~stat/SWITCH2","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"B4D6C7_SW_2","device":{"identifiers":["B4D6C7"],"connections":[["mac","5C:CF:7F:B4:D6:C7"]]},"~":"Quad/","value_template":"{%if is_state(entity_id,\"on\")-%}OFF{%-else-%}ON{%-endif%}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/3F0954_BTN_1/config' with data '{"name":"Shed Button1","stat_t":"~stat/BUTTON1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"3F0954_BTN_1","device":{"identifiers":["3F0954"],"connections":[["mac","60:01:94:3F:09:54"]]},"~":"Shed/","value_template":"{{value_json.STATE}}","pl_on":"TOGGLE","off_delay":1}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/BD60E3_BTN_1/config' with data '{"name":"TasmoTest Button1","stat_t":"~stat/BUTTON1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E3_BTN_1","device":{"identifiers":["BD60E3"],"connections":[["mac","5C:CF:7F:BD:60:E3"]]},"~":"TasmoTest/","value_template":"{{value_json.STATE}}","pl_on":"TOGGLE","off_delay":1}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/3EACDB_BTN_1/config' with data '{"name":"Egg Button1","stat_t":"~stat/BUTTON1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"3EACDB_BTN_1","device":{"identifiers":["3EACDB"],"connections":[["mac","60:01:94:3E:AC:DB"]]},"~":"Egg/","value_template":"{{value_json.STATE}}","pl_on":"TOGGLE","off_delay":1}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/BD60E7_BTN_1/config' with data '{"name":"Temp CV Button1","stat_t":"~stat/BUTTON1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_BTN_1","device":{"identifiers":["BD60E7"],"connections":[["mac","5C:CF:7F:BD:60:E7"]]},"~":"Temperatures/","value_template":"{{value_json.STATE}}","pl_on":"TOGGLE","off_delay":1}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/binary_sensor/BD7C88_BTN_1/config' with data '{"name":"TV Button1","stat_t":"~stat/BUTTON1","avty_t":"~tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD7C88_BTN_1","device":{"identifiers":["BD7C88"],"connections":[["mac","5C:CF:7F:BD:7C:88"]]},"~":"TV/","value_template":"{{value_json.STATE}}","pl_on":"TOGGLE","off_delay":1}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/B4D6C7_status/config' with data '{"name":"Amplifier status","stat_t":"~HASS_STATE","avty_t":"~LWT","frc_upd":true,"pl_avail":"Online","pl_not_avail":"Offline","json_attributes_topic":"~HASS_STATE","unit_of_meas":" ","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"B4D6C7_status","device":{"identifiers":["B4D6C7"],"connections":[["mac","5C:CF:7F:B4:D6:C7"]],"name":"Amplifier","model":"Sonoff Basic","sw_version":"8.1.0(tasmota)","manufacturer":"Tasmota"},"~":"Quad/tele/"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/3F0954_status/config' with data '{"name":"Shed status","stat_t":"Shed/tele/HASS_STATE","avty_t":"Shed/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"Shed/tele/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"3F0954_status","dev":{"ids":["3F0954"],"name":"Shed","mdl":"Generic","sw":"8.5.0(tasmota)","mf":"Tasmota"}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E3_status/config' with data '{"name":"Sonoff Basic status","stat_t":"TasmoTest/tele/HASS_STATE","avty_t":"TasmoTest/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"TasmoTest/tele/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"BD60E3_status","dev":{"ids":["BD60E3"],"name":"Sonoff Basic","mdl":"Sonoff Basic","sw":"8.3.0(tasmota)","mf":"Tasmota"}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/3EACDB_status/config' with data '{"name":"Egg status","stat_t":"Egg/tele/HASS_STATE","avty_t":"Egg/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"Egg/tele/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"3EACDB_status","dev":{"ids":["3EACDB"],"name":"Egg","mdl":"Sonoff Basic","sw":"8.5.0(tasmota)","mf":"Tasmota"}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-1_Id/config' with data '{"name":"Temp CV DS18B20-1 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-1_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-1']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-1_Temperature/config' with data '{"name":"Temp CV DS18B20-1 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-1_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-1']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-2_Id/config' with data '{"name":"Temp CV DS18B20-2 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-2_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-2']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-2_Temperature/config' with data '{"name":"Temp CV DS18B20-2 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-2_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-2']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-3_Id/config' with data '{"name":"Temp CV DS18B20-3 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-3_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-3']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-3_Temperature/config' with data '{"name":"Temp CV DS18B20-3 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-3_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-3']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-4_Id/config' with data '{"name":"Temp CV DS18B20-4 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-4_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-4']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-4_Temperature/config' with data '{"name":"Temp CV DS18B20-4 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-4_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-4']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-5_Id/config' with data '{"name":"Temp CV DS18B20-5 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-5_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-5']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-5_Temperature/config' with data '{"name":"Temp CV DS18B20-5 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-5_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-5']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-6_Id/config' with data '{"name":"Temp CV DS18B20-6 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-6_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-6']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-6_Temperature/config' with data '{"name":"Temp CV DS18B20-6 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-6_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-6']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-7_Id/config' with data '{"name":"Temp CV DS18B20-7 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-7_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-7']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-7_Temperature/config' with data '{"name":"Temp CV DS18B20-7 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-7_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-7']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-8_Id/config' with data '{"name":"Temp CV DS18B20-8 Id","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-8_Id","dev":{"ids":["BD60E7"]},"unit_of_meas":" ","ic":"mdi:eye","frc_upd":true,"val_tpl":"{{value_json['DS18B20-8']['Id']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_DS18B20-8_Temperature/config' with data '{"name":"Temp CV DS18B20-8 Temperature","stat_t":"Temperatures/tele/SENSOR","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"BD60E7_DS18B20-8_Temperature","dev":{"ids":["BD60E7"]},"unit_of_meas":"°C","dev_cla":"temperature","frc_upd":true,"val_tpl":"{{value_json['DS18B20-8']['Temperature']}}"}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD60E7_status/config' with data '{"name":"Temp CV status","stat_t":"Temperatures/tele/HASS_STATE","avty_t":"Temperatures/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"Temperatures/tele/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"BD60E7_status","dev":{"ids":["BD60E7"],"name":"Temp CV","mdl":"Sonoff Basic","sw":"8.5.0(tasmota)","mf":"Tasmota"}}'
Zigbee2MQTT:debug 2020-10-06 10:12:28: Received MQTT message on 'homeassistant/sensor/BD7C88_status/config' with data '{"name":"TV status","stat_t":"TV/tele/HASS_STATE","avty_t":"TV/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"TV/tele/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"BD7C88_status","dev":{"ids":["BD7C88"],"name":"TV","mdl":"Sonoff Basic","sw":"8.5.0(tasmota)","mf":"Tasmota"}}'
Zigbee2MQTT:debug 2020-10-06 10:12:33: Received MQTT message on 'zigbee2mqtt/bridge/config/devices/get' with data ''
Zigbee2MQTT:info  2020-10-06 10:12:33: MQTT publish: topic 'zigbee2mqtt/bridge/config/devices', payload '[{"dateCode":"20190608","friendly_name":"Coordinator","ieeeAddr":"0x00124b0018e8847f","lastSeen":1601971953111,"networkAddress":0,"softwareBuildID":"zStack12","type":"Coordinator"}]'
Zigbee2MQTT:debug 2020-10-06 10:12:33: Received MQTT message on 'zigbee2mqtt/bridge/config/devices' with data '[{"dateCode":"20190608","friendly_name":"Coordinator","ieeeAddr":"0x00124b0018e8847f","lastSeen":1601971953111,"networkAddress":0,"softwareBuildID":"zStack12","type":"Coordinator"}]'
Zigbee2MQTT:info  2020-10-06 10:12:33: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":[{"dateCode":"20190608","friendly_name":"Coordinator","ieeeAddr":"0x00124b0018e8847f","lastSeen":1601971953120,"networ
Only the Coordinator shows up in Zigbee2Mqttassistant
Configuration and Log looks quite similar to mine. The log goes different from mine at the point
(mine says Currently 30 devices are joined:)
To me it looks like the cc2532 coordinator doesn’t see any devices.
You didn’t -by accident- changed the channel from 11 to 15 in the config (in Advanced) ?
As channel 11 is default like many other settings in your config).
I have always worked with channel 15 (don’t know why…). Took up your suggestion to change to Channel 11… Did not help…same problem
Hmm, something wrong with the cc2531?
It sometimes helped me to take out the cc2531 stick and insert it again after 10 seconds and restart the z2m addon.
Or try pairing a device (after resetting) with the current z2m setup to see if the cc2531 behaves normally.
Took out the cc2531 and then the RPI went into a reboot…
PS the subsequent restart of the z2m addon did not help. So I am gonna order a new dongle.
Did you try this?
just did… and it worked :smile: I could get a new device paired. But all of my existing devices are still not available?
Ok good, then the problem is something else. A new cc2531 will not help I’m afraid.
Edit:
I tried to find other differences in log and config, but didn’t see anything useful, sorry.
Of course there is the possibility to re-pair all your devices, but that is somewhat uncomfortable as the cause of your problem is not yet known.
Perhaps someone else can shed a light on this.
Finally I decided to restore a complete snapshot from 48 hours ago… and now everything is working fine again. Thnx: gedeelde smart is halve smart. Mystery remains
Which z2mqtt version do you have? 1.15.0?
yes indeed 1.15.0
System Health
arch armv7l
chassis
dev false
docker true
docker_version 19.03.12
hassio true
host_os Raspbian GNU/Linux 10 (buster)
installation_type Home Assistant Supervised
os_name Linux
os_version 5.4.51-v7l+
python_version 3.8.5
supervisor 245
timezone Europe/Amsterdam
version 0.115.6
virtualenv false
Lovelace
dashboards 1
mode storage
resources 2
views 13
Ok, great that it works again after a complete snapshot restore! You didn’t see any changes in the config? Good luck with z2m expansions :slightly_smiling_face:. Mvg!
Did you by any chance switch from dev to stable? Did you check the config dir for a backup of the database? It might be related to something I’ve just encountered: https://github.com/Koenkk/zigbee2mqtt/issues/2160
Thnx for the tip, I stayed on stable, restored a snapshot but I kept problems that the devices were suddenly no longer responsive after 2 or 10 days. Very irritating. Since I have 40+ devices, I changed the firmware of the coordinator: according to this scheme: https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator
So now I keep my fingers crossed
I’ve just found this thread after experiencing the exact same problem. It happened when I upgraded to 1.17.0.1 from 1.16.something, but that may be coincidence.
I’ll restore from yesterday’s snapshot tomorrow morning and report back.
OK, restoring from a snapshot taken before the upgrade didn’t help. However, luckily the host Pi is backed up nightly using rsnapshot, so I can dig through previous backups.
I found what looks like a good database.db file (i.e. it’s bigger than the default), but I’m not sure how to proceed.
I tried copying it to the docker host, using docker cp to copy it into the running container and then restarting the container. No joy (The container has to be running for the docker cp to work).
I know nothing about node.js or how the container is structured, so is there a way to stop the zigb2mqtt process without stopping the container?
As an aside, I was surprised to see that the folder /usr/share/zigbee2mqtt was not being mounted from the host file system as (I think) it means the database gets lost if the container is replaced. Maybe this is the source of the original problem?
Sorry, can’t help you here, I am running HA on a dedicated NUC
Also have this problem
