I have installed Home Assistant on proxmox and running the latest version of Home Assistant, zigbee2mqtt add-on and Mosquitto broker add-on.
In my devices.yaml (located in \share\zigbee2mqtt) I added the option
qos: 2
'0x00178801030c0f36':
friendly_name: Lamp_1e_verdieping_hal
qos: 2
'0x0017880102f9f505':
friendly_name: Lamp_2e_verdieping_hal
qos: 2
'0x0017880102f9ef1f':
friendly_name: Lamp_toilet
qos: 2
When I check Mqtt explorer I see QoS: 0
Why does mqtt explorer reported QoS: 0? Did I do something wrong?
This is my Home Assistant Zigbee2mqtt config
data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://core-mosquitto'
user: *
password: *
serial:
port: /dev/ttyACM0
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental:
new_api: true
socat:
enabled: false
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
restartdelay: 1
initialdelay: 1
options: '-d -d'
log: false
This is my Home Assistnat mosquitto config
logins:
- username: *
password: *
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
