My setup:
Sonoff Zigbee Bridge (tasmota zbbridge.bin latest)
MQTT mosquitto broker (not add-on)
zigbee2mqtt edge add-on
Sengled Smart LED multicolor A19 bulb E21-N1EA
zigbee2mqtt discovered some effects, like blink, breathe, ok
Home Assistant front end (lovelace) lists these effects as well.
When I select any effect it doesn’t seem to work.
Developer Tools provides supported_features: 63, which means that this bulb supports effects
SUPPORT_BRIGHTNESS = 1 - yes
SUPPORT_COLOR_TEMP = 2 - yes
SUPPORT_EFFECT = 4 - yes
SUPPORT_FLASH = 8 - yes
SUPPORT_COLOR = 16 - yes
SUPPORT_TRANSITION = 32 - yes
SUPPORT_WHITE_VALUE = 128 - no
I have created a test automation with the selected ‘blink’ effect:
command_topic:
zigbee2mqtt/Sengled_Light/set:
{"state": "ON", "color": {"x": 0.701, "y": 0.299}, "brightness": 152, "effect": "blink"}
state_topic:
{"brightness":152,"color":{"x":0.701,"y":0.299},"color_mode":"xy","linkquality":255,"state":"ON"}
Should an effect be listed in the state payload if it is supported and activated?
Transition from OFF to ON doesn’t work, but it works for ON to OFF
I do not know what to blame Sonoff bridge, add-on , bulb …
How the add-on gets information on all supported features by the discovered device?
I can implement those effects by scenes, scripts and automatons but it would be nice to have all features that are listed as supported.
This is my only zigbee bulb so I can’t compare to any other zigbee one.
And this is my first zigbee experience and not completely sold on it yet (currently on zwave).
I would appreciate any ideas.
