🧯 Zigbee2MQTT Aqara Magic Cube T1-Pro CTP-R01 Xiaomi Lumi cagl02
I can’t quite tell what you are doing, but in general you download/install the blueprint, then select it in the automation ui editor one of a couple of ways.
Once there you find the line item you want to add stuff to, in this case action CW side 3 and action ccw side three.
select call service, change to edit in yaml, then paste the provided code in.
The script part is a script, added via the script ui editor. Script ui editor, edit in yaml, paste in the whole script section except the word script:
If you want to see it in use, look at my personal configuration…
