Zigbee2MQTT - Aqara Wireless Mini Switch (WXKG11LM)
Blueprint for Aqara Wireless Mini Switch (WXKG11LM)
Integration:
Zigbee2MQTT 2.x
Device:
Aqara Wireless Mini Switch (WXKG11LM) (https://www.zigbee2mqtt.io/devices/WXKG11LM.html)
Action:
  • Button Single Press
  • Button Double Press
  • Button Hold
  • Button Released
Blueprint:
blueprint:
  name: Aqara Wireless Mini Switch (WXKG11LM)
  description: Aqara Wireless Mini Switch (WXKG11LM)
  domain: automation
  input:
    switch:
      selector:
        entity:
          domain:
          - sensor
          integration: mqtt
          multiple: false
    press_single:
      name: Single button press
      description: Action to run on single button press
      default: []
      selector:
        action: {}
    press_double:
      name: Double button press
      description: Action to run on double button press
      default: []
      selector:
        action: {}
    hold:
      description: Action to perform when the button is held
      default: []
      selector:
        action: {}
    release:
      description: Action to perform when the button is released
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zigbee2mqtt-aqara-wireless-mini-switch-wxkg11lm/810035
mode: queued
max_exceeded: silent
- platform: state
  entity_id: !input switch
- variables:
    command: '{{ trigger.to_state.state }}'
- choose:
  - conditions:
    - '{{ command == ''single'' }}'
    sequence: !input press_single
  - conditions:
    - '{{ command == ''double'' }}'
    sequence: !input press_double
  - conditions:
    - '{{ command == ''hold'' }}'
    sequence: !input hold
  - conditions:
    - '{{ command == ''release'' }}'
    sequence: !input release
couldn’t get this working. only lets me select the battery sensor or temp sensor. any chance you can assist?
I’ve had the same issue with Homeassistant 2025.3.3, did some debugging.
Had to change the domain to event, and replace trigger.to_state.state by trigger.to_state.attributes.event_type in the blueprint to get it to work.
Resulting updated blueprint:
blueprint:
  domain: automation
  input:
    switch:
      selector:
        entity:
          domain:
          - event
          integration: mqtt
          multiple: false
    press_single:
      default: []
      selector:
        action: {}
    press_double:
      default: []
      selector:
        action: {}
    hold:
      default: []
      selector:
        action: {}
    release:
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/zigbee2mqtt-aqara-wireless-mini-switch-wxkg11lm/810035/3
mode: queued
- platform: state
- variables:
    command: '{{ trigger.to_state.attributes.event_type }}'
- choose:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
