I’ve installed the addon successfully and added a few devices, but I can’t get the “Allow devices to join” automation to trigger as described in the github instructions. If I trigger the automation manually, I can pair devices no problem, but I can’t see what’s wrong with the automation:
That’s the strange thing. If I do that the automation runs and I can add devices.
Setting the input_boolean.zigbee_permit_join to on thein either via Lovelace or manually does not trigger the automation.
Yes, thanks I checked that. However, after a few glasses of wine and a good night’s sleep I realised that the automation needed initial_state: on added to it before it would run.
Sorted, thanks for the help.
To be technical it does not need initial state on. But you do need to turn it on.
initial state tells home assistant what to do on startup
initial_state: on - whenever home assistant starts the automation wil be turned on
initial_state: off - whenever home assistant starts the automation will be turned off
initial_state not set - whenever home assistant is started the automation will resume the on/off state that it was in before the restart - this is what most people actually want. If you set initial _state to on, if you turn an automation off because it is doing weird shit, or you simply don’t need it at the moment, then restart HA, it will be turned on again, contrary to expectation.
