I have a problem with pairing Hue Dimmer with Hue Bulb.
Both devices are factory reset and already joined to my network (Conbee2 + Zigbee2Mqtt).
At this point I would expect possibility to bind them together directly, to make Dimmer control the bulb even without HA.
Unfortunatelly normal pairing procedure doesn’t work. Binding in z2m makes no difference either.
Also it’s strange that the dimmer is linked to distant hue led strip instead of this (hue_livingroom1)
Any cues about what to do?
BTW I found that all my hue devices are bound to coordinator. All but HueGo. Is it expected?
