My Raspberry Pi 4B + CC2652P was working fine till first power outage. After restart it’s stuck in the loop. Ui is showing 502 Bad Gateway error and in console i get this all the time.
Zigbee2MQTT:error 2022-01-19 21:06:21: MQTT failed to connect: getaddrinfo ENOTFOUND core-mosquitto
Zigbee2MQTT:error 2022-01-19 21:06:21: Exiting...
[21:06:31] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start
> node index.js
Here’s my config:
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
serial:
port: >-
/dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-port0
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability: false
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
And here also network bottom line:
Network
Container | Host | Description |
8485/tcp | Socat tcp-listen port |
Anybody had sth similar?
