Zigbee2MQTT BSEED Touch Dimmer TS0601 external converter
I hope anyone can help me:
I bought the BSEED Touch Dimmer without checking if it is supported :man_facepalming:
However: I tried to solve this with an external converter:
const fz = {...require('zigbee-herdsman-converters/converters/fromZigbee'), legacy: require('zigbee-herdsman-converters/lib/legacy').fromZigbee};
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const extend = require('zigbee-herdsman-converters/lib/extend');
const e = exposes.presets;
const ea = exposes.access;
const definition = {
    fingerprint: [
        {modelID: 'TS0601', manufacturerName: '_TZE204_n9ctkb6j'},
    model: 'TS0601_dimmer',
    vendor: 'TuYa',
    description: 'Zigbee smart dimmer',
    fromZigbee: [fz.tuya_dimmer, fz.ignore_basic_report],
    toZigbee: [tz.tuya_dimmer_state, tz.tuya_dimmer_level],
    configure: async (device, coordinatorEndpoint, logger) => {
        const endpoint = device.getEndpoint(1);
        await reporting.bind(endpoint, coordinatorEndpoint, ['genOnOff', 'genLevelCtrl']);
    exposes: [e.light_brightness().setAccess('state', ea.STATE_SET).setAccess('brightness', ea.STATE_SET)],
    whiteLabel: [
        {vendor: 'Larkkey', model: 'ZSTY-SM-1DMZG-EU'},
        {vendor: 'Earda', model: 'EDM-1ZAA-EU'},
        {vendor: 'Earda', model: 'EDM-1ZAB-EU'},
        {vendor: 'Earda', model: 'EDM-1ZBA-EU'},
        {vendor: 'Mercator Ikuü', model: 'SSWD01'},
module.exports = definition;
But when I restart Zigbee2MQTT addon, it doesn’t start up and throws this error in the logs:
/app/node_modules/zigbee-herdsman-converters/index.js:69
    definition.toZigbee.push(tz.scene_store, tz.scene_recall, tz.scene_add, tz.scene_remove, tz.scene_remove_all, tz.scene_rename, tz.read, tz.write, tz.command, tz.factory_reset);
TypeError: Cannot read properties of undefined (reading 'push')
    at Object.addDefinition [as addDeviceDefinition] (/app/node_modules/zigbee-herdsman-converters/index.js:69:25)
    at new ExternalConverters (/app/lib/extension/externalConverters.ts:15:17)
    at new Controller (/app/lib/controller.ts:84:58)
    at start (/app/index.js:106:18)
Does anyone know where is the error in my script?
Many thanks in advance :slight_smile:
I bought the same switch three months ago, its discovered by ZHA and Zigbee2Mqtt but without any entities, did you find any solution?
thanks.
Hi.
No, unfortunately I did not find any solution for this problem.
Sadly I’m using that swith till now without any smart functions.
Till now I hope that there is someone out there who can help with this.
