I just configured CC2531 Zigbee USB Dongle with zigbee2MQTT.
it works fine with my own mqtt server.
data_path: /config/zigbee2mqtt
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://192.168.0.25:1883'
serial:
port: /dev/ttyACM0
advanced:
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blacklist: []
ban: []
whitelist: []
queue: {}
socat:
enabled: true
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
restartdelay: 1
initialdelay: 1
options: '-d -d'
log: false
core-ssh: '/share/zigbee2mqtt#'
disable_led: true
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
#group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
broker: 127.0.0.1 # This will have to be your mqtt broker
port: 1883
discovery: true
input_boolean:
zigbee_permit_join:
name: Allow devices to join
initial: on
icon: mdi:cellphone-wireless
timer:
zigbee_permit_join:
name: Time remaining
duration: 600
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
group:
zigbee_group:
entities:
- input_boolean.zigbee_permit_join
- timer.zigbee_permit_join
- sensor.bridge_state
automation:
- id: enable_zigbee_join
alias: Enable Zigbee joining
#hide_entity: true
platform: state
entity_id: input_boolean.zigbee_permit_join
to: 'on'
- service: mqtt.publish
topic: zigbee2mqtt/bridge/config/permit_join
payload: 'true'
- service: timer.start
entity_id: timer.zigbee_permit_join
- id: disable_zigbee_join
alias: Disable Zigbee joining
- entity_id: input_boolean.zigbee_permit_join
platform: state
to: 'off'
- data:
payload: 'false'
- data:
service: timer.cancel
hide_entity: true
- id: disable_zigbee_join_timer
alias: Disable Zigbee joining by timer
hide_entity: true
- platform: event
event_type: timer.finished
event_data:
payload: 'false'
Now, i would like to use OSRAM SMART+ button to increase or decrease light walue.
Here is MQTT payload :
zigbee2mqtt:info 2020-02-22 11:34:59: Successfully configured '0x000d6f001019e83a'
zigbee2mqtt:info 2020-02-22 11:37:15: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"action":"circle_click","linkquality":68}'
zigbee2mqtt:info 2020-02-22 11:37:15: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":68,"action":""}'
zigbee2mqtt:info 2020-02-22 11:37:16: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":73,"action":"up"}'
zigbee2mqtt:info 2020-02-22 11:37:16: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":73,"action":""}'
zigbee2mqtt:info 2020-02-22 11:37:18: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":76,"action":"down"}'
zigbee2mqtt:info 2020-02-22 11:37:18: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":76,"action":""}'
zigbee2mqtt:info 2020-02-22 11:37:19: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":76,"action":"circle_click"}'
zigbee2mqtt:info 2020-02-22 11:37:19: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":76,"action":""}'
zigbee2mqtt:info 2020-02-22 11:37:20: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":76,"action":"up"}'
zigbee2mqtt:info 2020-02-22 11:37:20: MQTT publish: topic 'zigbee2mqtt/0x000d6f001019e83a', payload '{"linkquality":76,"action":""}'
Here is MQTT payload for lamp :
zigbee2mqtt:info 2020-02-22 11:45:06: MQTT publish: topic 'zigbee2mqtt/0x84182600000f971c', payload '{"state":"ON"}'
zigbee2mqtt:info 2020-02-22 11:45:10: MQTT publish: topic 'zigbee2mqtt/0x84182600000f971c', payload '{"state":"OFF"}'
zigbee2mqtt:info 2020-02-22 12:12:21: MQTT publish: topic 'zigbee2mqtt/0x84182600000f971c', payload '{"state":"ON","brightness":66}'
zigbee2mqtt:info 2020-02-22 12:12:24: MQTT publish: topic 'zigbee2mqtt/0x7cb03eaa0a05cd84', payload '{"state":"ON","brightness":112}'
I do not really know how i can change brightness value with a button.
Is someone can help me whith this ?
Thank.
