Dear all,
I am starting with homeassistant.
I installed it on a Rasberry pi4.
Now I am trying to install zigbee2MQTT. I have a zigate dongle for zigbee protocle.
I installed mosquitto broker. Inside the configuration of mosquitto I ask mosquitto to login on a secondary user.
I installed Zigbee2MQTT with this configuration:
homeassistant: true
advanced:
network_key:
- 118
- 19
- 146
- 88
- 43
- 206
- 166
- 13
- 102
- 43
- 65
- 35
- 7
- 35
- 203
- 19
pan_id: 34255
ext_pan_id:
- 110
- 162
- 108
- 128
- 210
- 142
- 164
- 136
mqtt:
base_topic: zigbee2mqtt
user: default
password: default
server: mqtt://core-mosquitto:1883
serial:
port: /dev/ttyUSB0
adapter: zigate
zigbee_herdsman_debug: true
frontend:
port: 8099
Then it works one time and after a reboot and with the update of zigbee2MQTT it doesn’t work anymore
Do you have an idea please?
This is my log:
debug 2024-01-03 16:16:22: Loaded state from file /config/zigbee2mqtt/state.json
info 2024-01-03 16:16:22: Logging to console and directory: '/config/zigbee2mqtt/log/2024-01-03.16-16-22' filename: log.txt
debug 2024-01-03 16:16:22: Removing old log directory '/config/zigbee2mqtt/log/2024-01-03.16-14-05'
info 2024-01-03 16:16:22: Starting Zigbee2MQTT version 1.35.0 (commit #unknown)
info 2024-01-03 16:16:22: Starting zigbee-herdsman (0.30.0)
debug 2024-01-03 16:16:22: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[110,162,108,128,210,142,164,136],"networkKey":"HIDDEN","panID":34255},"serialPort":{"adapter":"zigate","path":"/dev/ttyUSB0"}}'
error 2024-01-03 16:16:28: Error while starting zigbee-herdsman
error 2024-01-03 16:16:28: Failed to start zigbee
error 2024-01-03 16:16:28: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
error 2024-01-03 16:16:28: Exiting...
error 2024-01-03 16:16:28: Error: failed to connect to zigate adapter [object Object] after 5000ms
at ZiGateAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/zigate/adapter/zigateAdapter.ts:101:19)
at runNextTicks (node:internal/process/task_queues:60:5)
at listOnTimeout (node:internal/timers:538:9)
at processTimers (node:internal/timers:512:7)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:60:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
