Hey guys, I am currently trying to pair my new SONOFF devices via zigbee2mqtt to use them with HA. Sadly, I don’t know why, but I can’t pair devices anymore. I’ve already sent some devices back because I thought they are broken, but the new ones can also not be paired, so I think it might be a problem with my setup.
I think it must be something with zigbee2mqtt, because I don’t see any pairing messages in the logs for the new devices.
Got the same issue. Got 5 devices connected for over a year now. Bought some new ones over the holidays, but can’t seem to be able to add any new device. Don’t see any message related to pairing in the logs.
Do your 2.4Ghz WiFi and Zigbee channels overlap? I think the default channel for zigbee2mqtt is 11, which overlaps with WiFi channel 1. If there’s overlap, your issues may be due to interference.
It worked! Once I changed the channel & restarted, all known devices were gone. But I was once again able to add new devices. For the sake of it, I also tried to default channel (11), and that worked too. So looks like it has more to do with a reset than with the channel.
Only the Sonoff Wifi devices. The Sonoff Zigbee devices work out of the box with Zigbee2MQTT or Zigbee2Tasmota. Only pairing needed with a supported coordinator.
Regarding the wifi channel: My Wifi (2,4ghz) is configured to use channel 6, but there are three other Wifis (low signal strength!) that use channel 11.
I have two CC2531 sticks:
The first one has 10 connected devices (Aqara, Philips Hue, Tink) and works fine, but pairing does not work anymore.
The second one has 1 connected device (Philips Hue) and works fine.
Pairing the SONOFF devices does not work with any of these CC2531 sticks. There is nothing showing up in the logs. Really nothing. No “hey, this devices is unsupported” nor any warning or error. Nothing.
Each Zigbee network can only have one (1) coordinator.
As soon as you activate a second coordinator, you effectively establish a second independent Zigbee network. I’m not saying this is impossible or problematic, but it can be. So unless this is part of your network plan and you know what you are doing, I think your array of possible problems can be reduced if you avoid more electronic noise than needed.
As already mentioned, I’ve only used the second stick (+ separate zigbee2mqtt setup) for testing the pairing. It worked. That’s all I did so far with the second stick. It is not active at the moment.
I’ve noticed with my cc2530 that I need to physically power it off sometimes for it to accept new devices. It also depends which firmware you’re using on your coordinator as to how many devices it can accept. Looks like you have a couple of routers so you should be ok though.
Ooooooookay, seems like everything is working again. I think turning the whole system off, waiting a few minutes and starting everything up again solved the problems I was able to pair my SONOFF switch and my SONOFF temperature/humidity sensors!
