Zigbee2mqtt change channel issue
On zigbee2mqtt even if I’m on permit join, my devices are note seen, and some of them didn’t respond. I made a backup but still the same, no one answers and new devices are not detected. I deleted and try again to put them but not detected….
I am on permit join true, and if I disconnect the adapter it shows me « adapter disconnected, stopping »
Think we need a few more informations. You mention channel change, from what and to what. And you devices, are you reparieng them? They will not work otherwise.
The channel is 25
After many tries, one device has been seen (so after channel change), but doesn’t work :
Error <small>2023-09-16 20:44:07</small>`Publish 'set' 'state' to '0xa4c1384fef66d1d1' failed: 'Error: Command 0xa4c1384fef66d1d1/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 60117 - 1 - 3 - 6 - 11 after 10000ms)'`
Info <small>2023-09-16 20:44:07</small>`MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to '0xa4c1384fef66d1d1' failed: 'Error: Command 0xa4c1384fef66d1d1/1 genOnOff.off({}, {\"sendWhen\":\"immediate\",\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (Timeout - 60117 - 1 - 3 - 6 - 11 after 10000ms)'","meta":{"friendly_name":"0xa4c1384fef66d1d1"},"type":"zigbee_publish_error"}'`
Info <small>2023-09-16 20:44:07</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":195,"power":null,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":null}'`
Info <small>2023-09-16 20:44:07</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":198,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":null}'`
Info <small>2023-09-16 20:44:07</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":195,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":null}'`
Info <small>2023-09-16 20:44:07</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":186,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":null}'`
Info <small>2023-09-16 20:44:07</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":189,"power":null,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":null}'`
Info <small>2023-09-16 20:44:08</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":0,"energy":null,"indicator_mode":null,"linkquality":195,"power":0,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":237}'`
Info <small>2023-09-16 20:44:08</small>`MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":0,"energy":8.94,"indicator_mode":null,"linkquality":195,"power":0,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":237}'`
My sonos controller (which was the first device not working) is not good : failed to set up
o
Z2M log after restart, can you post that. Does it show a working zigbee network. I know there is no devices, however is Z2M working? What Channel did you change from, the standard 11 or?
Have you changed any other settings, like PanID?
How big is the zigbee network, and are it contaning both end-devices and mains?
Are you sure it have changed channel?
log restart :
[20:50:44] INFO: Preparing to start...
[20:50:45] INFO: Socat not enabled
[20:50:47] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2023-09-16 20:50:53: Logging to console and directory: '/config/zigbee2mqtt/log/2023-09-16.20-50-53' filename: log.txt
Zigbee2MQTT:info  2023-09-16 20:50:53: Starting Zigbee2MQTT version 1.33.0 (commit #unknown)
Zigbee2MQTT:info  2023-09-16 20:50:53: Starting zigbee-herdsman (0.18.5)
Zigbee2MQTT:info  2023-09-16 20:51:04: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2023-09-16 20:51:04: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info  2023-09-16 20:51:04: Currently 5 devices are joined:
Zigbee2MQTT:info  2023-09-16 20:51:04: 0xec1bbdfffe37cebc (0xec1bbdfffe37cebc): Not supported (Unknown)
Zigbee2MQTT:info  2023-09-16 20:51:04: 0xa4c1384fef66d1d1 (0xa4c1384fef66d1d1): A1Z - Nous Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info  2023-09-16 20:51:04: Dimmer Salon Entrée (0x001788010c2b5f60): 929002398602 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:info  2023-09-16 20:51:04: Dimmer Salon Couloir (0x001788010d263615): 929002398602 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:info  2023-09-16 20:51:04: Dimmer Entrée (0x001788010c2a572b): 929002398602 - Philips Hue dimmer switch (EndDevice)
Zigbee2MQTT:warn  2023-09-16 20:51:04: `permit_join` set to  `true` in configuration.yaml.
Zigbee2MQTT:warn  2023-09-16 20:51:04: Allowing new devices to join.
Zigbee2MQTT:warn  2023-09-16 20:51:04: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info  2023-09-16 20:51:04: Zigbee: allowing new devices to join.
Zigbee2MQTT:info  2023-09-16 20:51:04: Connecting to MQTT server at mqtt://core-mosquitto
Zigbee2MQTT:info  2023-09-16 20:51:05: Connected to MQTT server
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info  2023-09-16 20:51:05: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"},"log_level":"info","network":{"channel":25,"extendedPanID":"0x00124b002a1ae62e","panID":6754},"permit_join":true,"version":"1.33.0"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/switch/0xa4c1384fef66d1d1/switch/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c1384fef66d1d1/set","device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":null,"object_id":"0xa4c1384fef66d1d1","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_switch_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/power_outage_memory/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"enabled_by_default":false,"entity_category":"config","icon":"mdi:power-settings","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Power outage memory","object_id":"0xa4c1384fef66d1d1_power_outage_memory","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_power_outage_memory_zigbee2mqtt","value_template":"{{ value_json.power_outage_memory }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/select/0xa4c1384fef66d1d1/power_outage_memory/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c1384fef66d1d1/set/power_outage_memory","device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"entity_category":"config","icon":"mdi:power-settings","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Power outage memory","object_id":"0xa4c1384fef66d1d1_power_outage_memory","options":["on","off","restore"],"origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_power_outage_memory_zigbee2mqtt","value_template":"{{ value_json.power_outage_memory }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/indicator_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"enabled_by_default":false,"json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Indicator mode","object_id":"0xa4c1384fef66d1d1_indicator_mode","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_indicator_mode_zigbee2mqtt","value_template":"{{ value_json.indicator_mode }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/select/0xa4c1384fef66d1d1/indicator_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c1384fef66d1d1/set/indicator_mode","device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Indicator mode","object_id":"0xa4c1384fef66d1d1_indicator_mode","options":["off","off/on","on/off","on"],"origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_indicator_mode_zigbee2mqtt","value_template":"{{ value_json.indicator_mode }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","object_id":"0xa4c1384fef66d1d1_power","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/current/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"device_class":"current","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","object_id":"0xa4c1384fef66d1d1_current","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_current_zigbee2mqtt","unit_of_measurement":"A","value_template":"{{ value_json.current }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","object_id":"0xa4c1384fef66d1d1_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_voltage_zigbee2mqtt","unit_of_measurement":"V","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/energy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"device_class":"energy","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","object_id":"0xa4c1384fef66d1d1_energy","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{ value_json.energy }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/lock/0xa4c1384fef66d1d1/child_lock/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/0xa4c1384fef66d1d1/set/child_lock","device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Child lock","object_id":"0xa4c1384fef66d1d1_child_lock","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_lock":"LOCK","payload_unlock":"UNLOCK","state_locked":"LOCK","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","state_unlocked":"UNLOCK","unique_id":"0xa4c1384fef66d1d1_child_lock_zigbee2mqtt","value_template":"{{ value_json.child_lock }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Linkquality","object_id":"0xa4c1384fef66d1d1_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0xa4c1384fef66d1d1/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":"Update state","object_id":"0xa4c1384fef66d1d1_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c1384fef66d1d1/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":null,"object_id":"0xa4c1384fef66d1d1_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/update/0xa4c1384fef66d1d1/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0xa4c1384fef66d1d1"],"manufacturer":"Nous","model":"Smart plug (with power monitoring) (A1Z)","name":"0xa4c1384fef66d1d1"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","name":null,"object_id":"0xa4c1384fef66d1d1","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0xa4c1384fef66d1d1\"}","state_topic":"zigbee2mqtt/0xa4c1384fef66d1d1","unique_id":"0xa4c1384fef66d1d1_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2b5f60/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2b5f60"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Entrée","sw_version":"2.45.2_hF4400CA"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Entrée","object_id":"dimmer_salon_entrée_battery","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Dimmer Salon Entrée","unique_id":"0x001788010c2b5f60_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2b5f60/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2b5f60"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Entrée","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Entrée","name":"Action","object_id":"dimmer_salon_entrée_action","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Dimmer Salon Entrée","unique_id":"0x001788010c2b5f60_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2b5f60/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2b5f60"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Entrée","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Entrée","name":"Linkquality","object_id":"dimmer_salon_entrée_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Dimmer Salon Entrée","unique_id":"0x001788010c2b5f60_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2b5f60/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2b5f60"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Entrée","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Entrée","name":"Update state","object_id":"dimmer_salon_entrée_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Dimmer Salon Entrée","unique_id":"0x001788010c2b5f60_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/binary_sensor/0x001788010c2b5f60/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2b5f60"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Entrée","sw_version":"2.45.2_hF4400CA"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Entrée","name":null,"object_id":"dimmer_salon_entrée_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Dimmer Salon Entrée","unique_id":"0x001788010c2b5f60_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/update/0x001788010c2b5f60/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x001788010c2b5f60"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Entrée","sw_version":"2.45.2_hF4400CA"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Entrée","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Dimmer Salon Entrée","name":null,"object_id":"dimmer_salon_entrée","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x001788010c2b5f60\"}","state_topic":"zigbee2mqtt/Dimmer Salon Entrée","unique_id":"0x001788010c2b5f60_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010d263615/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010d263615"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Couloir","sw_version":"2.45.2_hF4400CA"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Couloir","object_id":"dimmer_salon_couloir_battery","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Dimmer Salon Couloir","unique_id":"0x001788010d263615_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010d263615/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010d263615"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Couloir","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Couloir","name":"Action","object_id":"dimmer_salon_couloir_action","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Dimmer Salon Couloir","unique_id":"0x001788010d263615_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010d263615/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010d263615"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Couloir","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Couloir","name":"Linkquality","object_id":"dimmer_salon_couloir_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Dimmer Salon Couloir","unique_id":"0x001788010d263615_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010d263615/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010d263615"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Couloir","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Couloir","name":"Update state","object_id":"dimmer_salon_couloir_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Dimmer Salon Couloir","unique_id":"0x001788010d263615_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/binary_sensor/0x001788010d263615/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010d263615"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Couloir","sw_version":"2.45.2_hF4400CA"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Couloir","name":null,"object_id":"dimmer_salon_couloir_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Dimmer Salon Couloir","unique_id":"0x001788010d263615_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/update/0x001788010d263615/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x001788010d263615"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Salon Couloir","sw_version":"2.45.2_hF4400CA"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_topic":"zigbee2mqtt/Dimmer Salon Couloir","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Dimmer Salon Couloir","name":null,"object_id":"dimmer_salon_couloir","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x001788010d263615\"}","state_topic":"zigbee2mqtt/Dimmer Salon Couloir","unique_id":"0x001788010d263615_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2a572b/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2a572b"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Entrée","sw_version":"2.45.2_hF4400CA"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Dimmer Entrée","object_id":"dimmer_entrée_battery","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Dimmer Entrée","unique_id":"0x001788010c2a572b_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2a572b/action/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2a572b"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Entrée","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":true,"icon":"mdi:gesture-double-tap","json_attributes_topic":"zigbee2mqtt/Dimmer Entrée","name":"Action","object_id":"dimmer_entrée_action","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Dimmer Entrée","unique_id":"0x001788010c2a572b_action_zigbee2mqtt","value_template":"{{ value_json.action }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2a572b/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2a572b"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Entrée","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/Dimmer Entrée","name":"Linkquality","object_id":"dimmer_entrée_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/Dimmer Entrée","unique_id":"0x001788010c2a572b_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/sensor/0x001788010c2a572b/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2a572b"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Entrée","sw_version":"2.45.2_hF4400CA"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/Dimmer Entrée","name":"Update state","object_id":"dimmer_entrée_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Dimmer Entrée","unique_id":"0x001788010c2a572b_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/binary_sensor/0x001788010c2a572b/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x001788010c2a572b"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Entrée","sw_version":"2.45.2_hF4400CA"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/Dimmer Entrée","name":null,"object_id":"dimmer_entrée_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/Dimmer Entrée","unique_id":"0x001788010c2a572b_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'homeassistant/update/0x001788010c2a572b/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x001788010c2a572b"],"manufacturer":"Philips","model":"Hue dimmer switch (929002398602)","name":"Dimmer Entrée","sw_version":"2.45.2_hF4400CA"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_topic":"zigbee2mqtt/Dimmer Entrée","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/Dimmer Entrée","name":null,"object_id":"dimmer_entrée","origin":{"name":"Zigbee2MQTT","sw":"1.33.0","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x001788010c2a572b\"}","state_topic":"zigbee2mqtt/Dimmer Entrée","unique_id":"0x001788010c2a572b_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'zigbee2mqtt/0xa4c1384fef66d1d1', payload '{"child_lock":null,"current":0,"energy":8.94,"indicator_mode":null,"linkquality":192,"power":0,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":237}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'zigbee2mqtt/Dimmer Salon Entrée', payload '{"action":null,"battery":100,"linkquality":42,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'zigbee2mqtt/Dimmer Salon Couloir', payload '{"action":null,"battery":100,"linkquality":39,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info  2023-09-16 20:51:05: MQTT publish: topic 'zigbee2mqtt/Dimmer Entrée', payload '{"action":null,"battery":100,"linkquality":108,"update":{"installed_version":33565954,"latest_version":33565954,"state":"idle"},"update_available":false}'
Zigbee2MQTT:info  2023-09-16 20:51:05: Zigbee2MQTT started!
I changed the 11 to 25 (a part of configuration.yaml) :
  '0xec1bbdfffe37cebc':
    friendly_name: '0xec1bbdfffe37cebc'
  '0xa4c1384fef66d1d1':
    friendly_name: '0xa4c1384fef66d1d1'
advanced:
  log_syslog:
    app_name: Zigbee2MQTT
    eol: /n
    host: localhost
    localhost: localhost
    path: /dev/log
    pid: process.pid
    port: 514
    protocol: udp4
    type: '5424'
  channel: 25
seems to be working I can go to the frontend of z2m, and don’t think I changed any PANID for know
And I have only 5 devices on the network : 3 dimmers, one bulb, the controller sonos round, and 3 plug to be use as router
It finds my bulb but seems to be on channel 11
Not entirely sure on the new versions of Z2M, however when I changed channel from 11 to 25, I had to delete the configuration backup file, however think that is old information.
My configuration.yaml file is different from yours in regards to the channel input. It looks like this
advanced:
  log_level: error
  pan_id: 12
  channel: 25
On the screenshot, it says device is on channel 11. How to know if I put on channel 25 right or if I made a mistake ?
Here my advanced settings :
advanced:
  log_syslog:
    eol: /n
    host: localhost
    path: /dev/log
    pid: process.pid
    port: 514
    protocol: udp4
    type: '5424'
  channel: 25
Think the configuration is right, however if it shows channel 11, then it have not changed. You devices should also not re-connect without re-pairing, hence the coodicnator have probably not changed.
Do you have a configuration backup file in the Z2M directory? If yes, you need to delete it for Z2M make the change.
If there are no backup file, then try to change again in the
I had to re-paring
here my z2m directory :
So I have to delete the coordinator_backup.json and restart and that’s it ? Z2M will be ok ?
How to be sure devices are on channel 25 ? Don’t see the setting
If you open coordinator_backup.json you can see the channel used/
I Z2M front-end it should show under settings - advanced.
Think the logfile, during startup, will show the channel if you select “info” level.
So seems to be good
So, back to the original problem.
Was it stable on channel 11? The error is a timeout error.
Have you change anything else?
It was stable on channel 11, and just like that, sonos controller didn’t work, and the other went wrong … Without a change
The change from channel 11 to 25. Why did you make the change? Are you sure there are not interference on zigbeen channel 25. It is roughly same as wifi channel 12/13 and overlaping with wifi 11.
Do you have a fairly long USB extender cable?
I don’t know for the channel … I don’t know if it’s a good idea with my network… Don’t know how to choose.
I have a fairly long USB extender cable but why ? I have one but not used the dongle is on the pi
