LaUr3nTiU
(Laurentiu Tertan)
November 4, 2023, 5:05pm
1
I have a few ZBMINIL2 from SONOFF and they get integrated as switch, instead of as light.
I know I can change the switch to light using HA, but it’s annoying because it creates a helper entity.
I’ve modified the Z2M configuration to this:
devices:
"0x30fb10fffe6e9e0d":
type: light
But it doesn’t seem to be doing anything. Does anyone know of a correct syntax that would do this?
nickrout
(Nick Rout)
November 4, 2023, 8:47pm
2
Try single quotes, all the examples have single quotes.
LaUr3nTiU
(Laurentiu Tertan)
November 4, 2023, 11:26pm
3
I actually found Home Assistant | Zigbee2MQTT but it does not work.
The presented syntax looks like this:
devices:
"0x12345678":
friendly_name: my_switch
homeassistant:
switch:
type: light
object_id: light
light:
value_template: null
state_value_template: '{{ value_json.state }}'
nickrout
(Nick Rout)
November 5, 2023, 8:56am
4
That wasn’t the page I got the suggestion from, but it looks like the single/double quote thing was a red herring.
So does the setting you just posted work?
francisp
(Francis)
November 5, 2023, 9:08am
5
it is like this, look at the quotes:
'0x0c4314fffeb51643':
friendly_name: slaapkamer
homeassistant:
switch:
type: light
object_id: light
light:
LaUr3nTiU
(Laurentiu Tertan)
November 5, 2023, 12:38pm
6
Applied your change (with a name for light – licht_slaapkamer), but it still shows up as switch.my_switch in the MQTT integration.
Where are you adding the config for ‘0x0c4314fffeb51643’?
Mine is in the configuration of the Z2M addon, like:
serial:
port: /dev/ttyUSB0
zigbee_herdsman_debug: false
devices:
The thing with " vs ', is that I save it with single quotes, but after restart it gets translated to double quotes.
Edit: I removed and re-paired the device after the Z2M restart. I’ve also restarted Z2M without re-pairing and it still shows up as switch.my_switch instead of light.my_switch
Edit2: Well, this is odd. Looks like /config/zigbee2mqtt/devices.yaml does not have my changes from the Z2M addon?
/config/zigbee2mqtt/configuration.yaml does this:
devices:
- devices.yaml
Yet in my Z2M Addon I don’t have a “load”. What…?
LaUr3nTiU
(Laurentiu Tertan)
November 5, 2023, 12:47pm
7
Editing /config/zigbee2mqtt/configuration.yaml (and devices.yaml) solved this!
Why is the configuration from the addon page itself not being taken into account?
Just for future reference, if you are editing the configuration.yaml
, this must be done with Z2M down, otherwise it will overwrite your settings again.
