I’ve switched from Sonoff Dongle Plus to SMTECH SLZB-06. I’ve flashed IEEE ID to the same ID, and Z2M starts up fine.
I’m running largely IKEA devices with a few IKEA repeaters (and some Aqara sensors, but I know Aqara can be a bit flakey so testing has been limited to IKEA devices). Now the strange part:
IKEA devices that are end devices (e.g. switch, sensor) after power cycling appear and work as they used to.
IKEA devices that are routers (e.g. Smart Plug, USB powered air quality monitor) do not appear.
I cannot see any Aqara devices, but will deal with that down the road.
I’ve done the usual debugging by powering down all the mains powered ZigBee devices and also removing the repeaters completely from the equation. Rebooting HA between trials etc.
I’d rather not re-pair all devices, especially when I haven’t had to for some others !
Is there something obvious ? In summary anything that’s powered (assume a router) is not seen after coordinator change.
Thanks in advance for thoughts !
