Hi All,
Extremely new to HA.
I have HA set up on a RP4 with 4GB ram and on the surface appears to be operating correctly.
IP Address is 10.0.0.15
I have MQTT server and zigbee2mqtt set up on a RP3 and operating correctly. I can browse to the zigbee2mqtt web interface and add devices and these devices can be seen operating via MQTT explorer.
How do I setup HA so that it connects to the external zigbee2mqtt instance?
I have the following configured
This is the log information
[14:45:00] INFO: Preparing to start...
[14:45:01] INFO: Socat not enabled
[14:45:02] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-09-05 14:45:08: Logging to console and directory: '/config/zigbee2mqtt/log/2023-09-05.14-45-08' filename: log.txt
Zigbee2MQTT:info 2023-09-05 14:45:08: Starting Zigbee2MQTT version 1.33.0 (commit #unknown)
Zigbee2MQTT:info 2023-09-05 14:45:08: Starting zigbee-herdsman (0.18.5)
Zigbee2MQTT:error 2023-09-05 14:45:09: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-09-05 14:45:09: Failed to start zigbee
Zigbee2MQTT:error 2023-09-05 14:45:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-09-05 14:45:09: Exiting...
Zigbee2MQTT:error 2023-09-05 14:45:09: Error: Error while opening socket
at Socket.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:198:24)
at Socket.emit (node:events:525:35)
at emitErrorNT (node:internal/streams/destroy:157:8)
at emitErrorCloseNT (node:internal/streams/destroy:122:3)
at processTicksAndRejections (node:internal/process/task_queues:83:21)
With regard to the MQTT question, how do I add multiple external MQTT servers
It appears I can only have one (1) entry. I also have a MQTT server on 10.0.0.5 and 10.0.0.14
Thanks, Neil.
