Hello, I’m trying to configure zigbee2mqtt, but when I check my configuration.yaml from within the HA UI, it gives me the error
expected a dictionary for dictionary value @ data[‘packages’][‘sensor’]
Here’s my config:
configuration.yaml homeassistant section:
homeassistant:
packages: !include_dir_merge_named packages/
packages/zigbee2mqtt.yaml
# Input select for Zigbee2MQTT debug level
input_select:
zigbee2mqtt_log_level:
name: Zigbee2MQTT Log Level
options:
- debug
- info
- warn
- error
initial: info
icon: mdi:format-list-bulleted
# Input number for joining time remaining (in minutes)
input_number:
zigbee2mqtt_join_minutes:
name: "Zigbee2MQTT join minutes"
initial: 2
min: 1
max: 5
step: 1
mode: slider
# Input text to input Zigbee2MQTT friendly_name for scripts
input_text:
zigbee2mqtt_old_name:
name: Zigbee2MQTT Old Name
initial: ""
zigbee2mqtt_new_name:
name: Zigbee2MQTT New Name
initial: ""
zigbee2mqtt_remove:
initial: ""
# Scripts for renaming & removing devices
script:
zigbee2mqtt_rename:
alias: Zigbee2MQTT Rename
sequence:
service: mqtt.publish
data_template:
topic: zigbee2mqtt/bridge/config/rename
payload_template: >-
"old": "{{ states.input_text.zigbee2mqtt_old_name.state | string }}",
"new": "{{ states.input_text.zigbee2mqtt_new_name.state | string }}"
zigbee2mqtt_remove:
alias: Zigbee2MQTT Remove
sequence:
data_template:
topic: zigbee2mqtt/bridge/config/remove
payload_template: "{{ states.input_text.zigbee2mqtt_remove.state | string }}"
# Timer for joining time remaining
timer:
zigbee_permit_join:
name: Time remaining
# Sensor for monitoring the bridge state
- platform: mqtt
name: Zigbee2MQTT Bridge state
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
# Sensor for Showing the Zigbee2MQTT Version
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/config"
value_template: "{{ value_json.version }}"
icon: mdi:zigbee
# Sensor for Showing the Coordinator Version
- platform: mqtt
value_template: "{{ value_json.coordinator }}"
icon: mdi:chip
# Switch for enabling joining
switch:
- platform: mqtt
name: "Zigbee2MQTT Main join"
state_topic: "zigbee2mqtt/bridge/config/permit_join"
command_topic: "zigbee2mqtt/bridge/config/permit_join"
payload_on: "true"
payload_off: "false"
automation:
# Automation for sending MQTT message on input select change
- id: zigbee2mqtt_log_level
alias: Zigbee2MQTT log level
initial_state: "on"
platform: state
entity_id: input_select.zigbee2mqtt_log_level
- service: mqtt.publish
payload_template: "{{ states('input_select.zigbee2mqtt_log_level') }}"
topic: zigbee2mqtt/bridge/config/log_level
# Automation to start timer when enable join is turned on
- id: zigbee_join_enabled
alias: Zigbee Join Enabled
platform: state
entity_id: switch.zigbee2mqtt_main_join
to: "on"
service: timer.start
entity_id: timer.zigbee_permit_join
data_template:
duration: "{{ '00:0%i:00' % (states('input_number.zigbee2mqtt_join_minutes') | int ) }}"
# Automation to stop timer when switch turned off and turn off switch when timer finished
- id: zigbee_join_disabled
alias: Zigbee Join Disabled
- platform: event
event_type: timer.finished
event_data:
- platform: state
to: "off"
- service: timer.cancel
- service: switch.turn_off
- id: "zigbee2mqtt_create_notification_on_successfull_interview"
alias: Zigbee Device Joined Notification
platform: mqtt
topic: 'zigbee2mqtt/bridge/log'
condition:
condition: template
value_template: '{{trigger.payload_json.type == "pairing" and trigger.payload_json.message == "interview_successful"}}'
- service: persistent_notification.create
data_template:
title: Device joined the Zigbee2MQTT network
message: "Name: {{trigger.payload_json.meta.friendly_name}},
Vendor: {{trigger.payload_json.meta.vendor}},
Description: {{trigger.payload_json.meta.description}}"
