Hello
I have installed zigbee2mqtt on my Pi4 HomeAssistant.
I read that I can set config parameters via UI and also from /config/zigbee2mqtt/configuration.yaml
Issue is, whatever changes I make from UI, I do not see it gets changed in file at /config/zigbee2mqtt/configuration.yaml
Whatever changes I directly make via file editor /config/zigbee2mqtt/configuration.yaml, I do not see effect in UI.
I also deleted /config/zigbee2mqtt/configuration.yaml file and still add-on works properly.
following is my UI screenshot.
and following is the configuration.yaml code
homeassistant: true
advanced:
transmit_power: 20
network_key:
- 211
- 150
- 34
- 252
- 8
- 131
- 16
- 166
- 135
- 53
- 29
- 252
- 174
- 249
- 23
- 63
pan_id: 42963
ext_pan_id:
- 253
- 130
- 9
- 95
- 88
- 183
- 166
- 67
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
mqtt:
server: mqtt://core-mosquitto:1883
user: addons
password: opeeNgaivoshe
serial:
port: tcp://192.168.0.197:6638
baudrate: 115200
disable_led: false
frontend:
port: 8099
device_options:
legacy: false
