You did add rtscts: true already to serial ?
And 7.4.1 is known to be buggy.
This is 8.0.2:
This is 8.0.2:
my problem is solved and zigbee2mqtt is running
Firmware updated
Config File change to :
mqtt:
server: mqtt://core-mosquitto:1883
base_topic: zigbee2mqtt
version: 5
# Serial settings
serial:
port: /dev/ttyUSB0
adapter: zstack
# Set output power to max 20
advanced:
transmit_power: 20
channel: 11
pan_id: GENERATE
network_key: GENERATE
availability_blocklist: []
availability_passlist: []
last_seen: ISO_8601
log_level: info
homeassistant:
enabled: true
legacy_action_sensor: true
experimental_event_entities: false
permit_join: false
devices:
- devices.yaml
groups:
- groups.yaml
it may help anyone in my situation and thanks for your support
The adapter was changed to ember
You have a SLZB-07 with TI chipset ? Never seen before
https://smlight.tech/product/slzb-07/
or do you have a SLZB-07p7 ?
