I have just installed this BluePrint after I got a Frient Keyboard. Works perfectly when I key in the personally code and arm or disarm Alarmo.
What a nice work by @neliss and @AndrejDelany - thank you very much ![]()
I have NFC tagās setup to my Alarmo as well. The NFCās work when I scan on my Adonno, but when I scan the tags on my Frient Keyboard, then nothing happens.
Anyone who can point in any direction for how I get this to work?
Thank you very much in advance.
Actually the blueprint expects āpanicā to be pushed there. Please try to replace panic with emergency in the blueprint at this point:
{{ trigger.payload_json.action == "panic" }}
(This answer is valid for my own version of this blueprint - please check the link in the first post. Donāt know how to handle this with alarmo).
Further debugging is necessary here - maybe you can check, what information is send via mqtt if a tag is placed on the keypad. Maybe there is a tag id that could be set as password in the automation.
So, I am using the Develco KEYZB-110 and have it almost perfect. Everything seems to work fine, except the SOS button.
Latest Blueprint by array81
Thanks to @AndrejDelany, @neliss, @jsdphilly and @array81 for all your hard work. This latest version from @array81 combines everything so far.
- Is there way to make the SOS button work? OR how to I select it as a trigger in automation? Also how do I active it? hold it? double or triple click?
- When I try to arm my alarm (arm away, arm home or arm night) if there is a door open or window opened it wont let me. Is there way to make HOLD action on (arm away, arm home or arm night) to FORCE it to arm it in that particular state?
That will be awesome! Any help from any of you will be appreciated! ![]()
P.S. It has Smart RFID Reader. I have some NFC tags, and chips and cards. How do I use them with the Develco KEYZB-110 since it says they are supported?
Hey @array81 can you fix the SOS button on your Blueprint. I installed it and everything else works. Then I installed in addition @AndrejDelany Blueprint and I get this option in automation, to put an action to the āemergencyā button. HERE:
However I need to keep both Blueprints installed in order for this to work. I would love to have all the options in a single Blueprint. @array81 can you amend this fix please? ![]()
Here is his Blueprint code: Zigbee2MQTT - Sync Keypad and Alarm Control Panel States
I dont know how to amend the āSOS / Emergencyā part myself, but when both Blueprints are installed everything works.
In the Alarmo documentation I donāt find references to the PANIC status, so I donāt know how to add support since my Blueprint is based on the functionality of this component.
@array81 okay, I understand. I will keep both blueprints installed then. @AndrejDelany gives me the SOS button functionality, and yours everything else
If you are willing to take a look at his blueprint and reverse engineering it or maybe he can help with that. But not a Biggie, I got everything working now anyways, just wished was all in 1 blueprint. Thanks again for the hard work!
Does anybody have one of these which can be found on Aliexpress. I have some credit on there and would like to get one.
I have just gotten NFC tags to work with the device using the blueprint by array81
What I did was first go into MQTT ā Configure and subscribe to the alarm keypad e.g. zigbee2mqtt/Alarm Keypad (change this to your device name). Then tap an NFC tag onto the device and when it beeps press the unlock key. This is important as just tapping an NFC does nothing, even though it beeps, it simply sets an iternal code in the device to the NFCs ID.
Once you press unlock then a log should appear with "action": "disarm", and the action_code is filled with the NFC tag ID, copy this code. This is unique to each NFC and can be used to set that NFC as an alarm code. I went into Alarmo ā Codes ā New User and entered the code copied from the MQTT message and now when I tap the NFC and hit disarm the alarm disarms properly.
Hope this helps anyone looking to use NFC tags.
Now Iām searching for a way of somehow setting up Apple Home Key to work to eliminate the need for codes and NFC tags all together. If anyone has any idea if this is possible Iād love to hear how!
Wondering if anyone can help -
- I have three Centralite 3400 keypads which all correctly arm and disarm Alarmo (Home / Away / Night / Disarmed)
- The problems Iām looking for help with are:
- Canāt get the keypads to beep when the system is arming
- Canāt get the keypads to show the current status when woken up. Iāve moved them from my Hubitat setup where they did both, so I know the devices are capable.
Any clues???
nice blueprint! I noticed some discussions about supporting a third button (night mode) which is there with the very popular FRIENT keypad (zigbee), but I donāt see it in latest code , here is my update to support it:
alias: Alarmo Frient Keypad Sync
description: >-
https://community.home-assistant.io/t/zigbee2mqtt-control-alarmo-via-keypad/420016
triggers:
- entity_id: alarm_control_panel.master
to: disarmed
trigger: state
to: armed_home
trigger: state
to: armed_away
trigger: state
to: armed_night
trigger: state
to: arming
trigger: state
to: pending
trigger: state
to: triggered
trigger: state
- topic: zigbee2mqtt/Alarm Keypad
trigger: mqtt
- event_type: alarmo_failed_to_arm
trigger: event
- event_type: alarmo_command_success
trigger: event
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
sequence:
- data_template:
topic: zigbee2mqtt/Alarm Keypad/set
payload: |-
"arm_mode":
"mode": "disarm"
action: mqtt.publish
- conditions:
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "arm_day_zones"
- conditions:
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "arm_night_zones"
- conditions:
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "arm_all_zones"
- conditions:
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "exit_delay"
- conditions:
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "entry_delay"
- conditions:
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "in_alarm"
- conditions:
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.payload_json.action == \"disarm\" }}"
sequence:
- data:
code: "{{ trigger.payload_json.action_code }}"
context_id: "{{ trigger.payload_json.action_transaction }}"
action: alarmo.disarm
- conditions:
value_template: "{{ trigger.payload_json.action == \"arm_all_zones\" }}"
sequence:
- data:
mode: away
action: alarmo.arm
- conditions:
value_template: "{{ trigger.payload_json.action == \"arm_night_zones\" }}"
sequence:
- data:
mode: night
action: alarmo.arm
- conditions:
value_template: "{{ trigger.payload_json.action == \"arm_day_zones\" }}"
sequence:
- data:
mode: home
action: alarmo.arm
- conditions:
sequence:
- choose:
- conditions:
value_template: "{{ trigger.event.data.reason == 'invalid_code' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
"transaction": {{ trigger.event.data.context_id }},
"mode": "invalid_code"
- conditions:
value_template: "{{ trigger.event.data.reason == 'open_sensors' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "not_ready"
- conditions:
value_template: "{{ trigger.event.data.reason == 'not_allowed' }}"
value_template: "{{ trigger.event.data.command|lower == 'disarm' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "already_disarmed"
- conditions:
sequence:
- choose:
- conditions:
value_template: "{{ trigger.event.data.action == 'arm' }}"
value_template: "{{ trigger.event.data.context_id != null }}"
value_template: "{{ trigger.event.data.mode == 'away' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
- conditions:
value_template: "{{ trigger.event.data.mode == 'home' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
- conditions:
value_template: "{{ trigger.event.data.mode == 'night' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
- conditions:
value_template: "{{ trigger.event.data.action == 'disarm' }}"
sequence:
- data_template:
payload: |-
"arm_mode":
"mode": "disarm"
mode: parallel
max: 10
Looks like Z2M 2.0 has stopped this from working. Anyone got any ideas or pointers to get it sorted again?
EDIT: Issue resolved, simply repaired my keypad!
Thanks, this helped me with getting my NFC tags setup.
Looks interesting but these zigbee keypads are expensive or hard to find here in Europe. I was wondering if I could use a numeric USB keyboard directly connected to my raspberry pi. Only petsitters would use it from time to time. Does it make any sense? How should I proceed to make it work?
Thank you
This blueprint works perfect. But when i use (Alarmo Keypad Sync) i get always some errors in the zigbee2mqtt log when i armed and disarmed alarmo? When i disabled the blueprint the errors are gone.
I have the same issue, doesnāt appear to cause any problems but it would be good to know if it can be sorted!
@array81 I use your blueprint and got the SOS button working seperately by simply subscribing to the following mqtt message (the button needs to be held for 2-3 seconds for it to trigger the payload)
topic: zigbee2mqtt/Alarm Keypad/action
payload: emergency
trigger: mqtt
welcome!
and yes, canāt find them either. Want one of them actually⦠![]()
Hi Brian, Iām in the situation as you, but I canāt find where and how to subscribe to the mqtt topic. Can you please share? Thanks in advance.
Same situation here as well⦠How to subscribe to the mqtt topic?
