Zigbee2mqtt crash some times
Sometimes Zigbee2mqtt crash and watchdog don’t run again it.
Don’t understand the origin of the issue.
My Zigbee2mqtt log :
[11:48:40] INFO: Preparing to start...
[11:48:43] INFO: Socat not enabled
[11:48:49] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info  2024-04-17 11:49:14: Logging to console and directory: '/config/zigbee2mqtt/log/2024-04-17.11-49-14' filename: log.txt
Zigbee2MQTT:info  2024-04-17 11:49:15: Starting Zigbee2MQTT version 1.36.1 (commit #unknown)
Zigbee2MQTT:info  2024-04-17 11:49:15: Starting zigbee-herdsman (0.40.3)
Zigbee2MQTT:info  2024-04-17 11:49:31: zigbee-herdsman started (resumed)
Zigbee2MQTT:info  2024-04-17 11:49:31: Coordinator firmware version: '{"meta":{"maintrel":"3 ","majorrel":"6","minorrel":"10","product":8,"revision":"6.10.3.0 build 297"},"type":"EZSP v8"}'
Zigbee2MQTT:info  2024-04-17 11:49:31: Currently 6 devices are joined:
Zigbee2MQTT:info  2024-04-17 11:49:31: Température salon (0x54ef4410007def8b): VOCKQJK11LM - Aqara TVOC air quality monitor (EndDevice)
Zigbee2MQTT:info  2024-04-17 11:49:31: Détecteur ouverture porte baie vitrée (0xa4c1387421845932): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info  2024-04-17 11:49:31: Radiateur Masterbedroom (0x90395efffe2763c2): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info  2024-04-17 11:49:31: Radiateur chambre invité (0x90395efffe4b1c01): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info  2024-04-17 11:49:32: Radiateur bureau (0x90395efffe4b1be9): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info  2024-04-17 11:49:32: Radiateur salon (0xf4b3b1fffedd9a3c): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info  2024-04-17 11:49:32: Zigbee: disabling joining new devices.
Zigbee2MQTT:info  2024-04-17 11:49:32: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:error 2024-04-17 11:49:45: MQTT error: getaddrinfo EAI_AGAIN core-mosquitto
Zigbee2MQTT:error 2024-04-17 11:49:47: MQTT failed to connect, exiting...
Zigbee2MQTT:info  2024-04-17 11:49:48: Stopping zigbee-herdsman...
Zigbee2MQTT:error 2024-04-17 11:50:11: MQTT error: getaddrinfo EAI_AGAIN core-mosquitto
Zigbee2MQTT:info  2024-04-17 11:50:53: Connected to MQTT server
Zigbee2MQTT:info  2024-04-17 11:50:55: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Mosquitto log :
2024-04-17 10:25:35: Client <unknown> closed its connection.
2024-04-17 10:27:35: New connection from 172.30.32.2:33400 on port 1883.
2024-04-17 10:27:35: Client <unknown> closed its connection.
2024-04-17 10:29:35: New connection from 172.30.32.2:56210 on port 1883.
2024-04-17 10:29:35: Client <unknown> closed its connection.
2024-04-17 10:31:35: New connection from 172.30.32.2:43474 on port 1883.
2024-04-17 10:31:35: Client <unknown> closed its connection.
2024-04-17 10:33:35: New connection from 172.30.32.2:43828 on port 1883.
2024-04-17 10:33:35: Client <unknown> closed its connection.
2024-04-17 10:35:35: New connection from 172.30.32.2:34154 on port 1883.
2024-04-17 10:35:35: Client <unknown> closed its connection.
2024-04-17 10:37:35: New connection from 172.30.32.2:39728 on port 1883.
2024-04-17 10:37:35: Client <unknown> closed its connection.
2024-04-17 10:39:35: New connection from 172.30.32.2:54100 on port 1883.
2024-04-17 10:39:35: Client <unknown> closed its connection.
2024-04-17 10:41:35: New connection from 172.30.32.2:54310 on port 1883.
2024-04-17 10:41:35: Client <unknown> closed its connection.
2024-04-17 10:43:35: New connection from 172.30.32.2:48950 on port 1883.
2024-04-17 10:43:35: Client <unknown> closed its connection.
2024-04-17 10:45:35: New connection from 172.30.32.2:42520 on port 1883.
2024-04-17 10:45:35: Client <unknown> closed its connection.
2024-04-17 10:47:35: New connection from 172.30.32.2:54172 on port 1883.
2024-04-17 10:47:35: Client <unknown> closed its connection.
2024-04-17 10:49:35: New connection from 172.30.32.2:51326 on port 1883.
2024-04-17 10:49:35: Client <unknown> closed its connection.
2024-04-17 10:50:59: Saving in-memory database to /data//mosquitto.db.
2024-04-17 10:51:35: New connection from 172.30.32.2:33768 on port 1883.
2024-04-17 10:51:35: Client <unknown> closed its connection.
2024-04-17 10:53:35: New connection from 172.30.32.2:38444 on port 1883.
2024-04-17 10:53:35: Client <unknown> closed its connection.
2024-04-17 10:55:35: New connection from 172.30.32.2:44088 on port 1883.
2024-04-17 10:55:35: Client <unknown> closed its connection.
2024-04-17 10:57:35: New connection from 172.30.32.2:36318 on port 1883.
2024-04-17 10:57:35: Client <unknown> closed its connection.
2024-04-17 10:59:35: New connection from 172.30.32.2:41274 on port 1883.
2024-04-17 10:59:35: Client <unknown> closed its connection.
2024-04-17 11:01:35: New connection from 172.30.32.2:46772 on port 1883.
2024-04-17 11:01:35: Client <unknown> closed its connection.
2024-04-17 11:03:35: New connection from 172.30.32.2:45116 on port 1883.
2024-04-17 11:03:35: Client <unknown> closed its connection.
2024-04-17 11:05:35: New connection from 172.30.32.2:59440 on port 1883.
2024-04-17 11:05:35: Client <unknown> closed its connection.
2024-04-17 11:07:35: New connection from 172.30.32.2:48666 on port 1883.
2024-04-17 11:07:35: Client <unknown> closed its connection.
2024-04-17 11:09:35: New connection from 172.30.32.2:46252 on port 1883.
2024-04-17 11:09:35: Client <unknown> closed its connection.
2024-04-17 11:11:35: New connection from 172.30.32.2:55906 on port 1883.
2024-04-17 11:11:35: Client <unknown> closed its connection.
2024-04-17 11:13:35: New connection from 172.30.32.2:36430 on port 1883.
2024-04-17 11:13:35: Client <unknown> closed its connection.
2024-04-17 11:15:35: New connection from 172.30.32.2:37476 on port 1883.
2024-04-17 11:15:35: Client <unknown> closed its connection.
2024-04-17 11:17:35: New connection from 172.30.32.2:59218 on port 1883.
2024-04-17 11:17:35: Client <unknown> closed its connection.
2024-04-17 11:19:35: New connection from 172.30.32.2:34354 on port 1883.
2024-04-17 11:19:35: Client <unknown> closed its connection.
2024-04-17 11:21:00: Saving in-memory database to /data//mosquitto.db.
2024-04-17 11:21:35: New connection from 172.30.32.2:60850 on port 1883.
2024-04-17 11:21:35: Client <unknown> closed its connection.
2024-04-17 11:23:35: New connection from 172.30.32.2:39300 on port 1883.
2024-04-17 11:23:35: Client <unknown> closed its connection.
2024-04-17 11:25:35: New connection from 172.30.32.2:35680 on port 1883.
2024-04-17 11:25:35: Client <unknown> closed its connection.
2024-04-17 11:27:35: New connection from 172.30.32.2:53134 on port 1883.
2024-04-17 11:27:35: Client <unknown> closed its connection.
2024-04-17 11:29:35: New connection from 172.30.32.2:51942 on port 1883.
2024-04-17 11:29:35: Client <unknown> closed its connection.
2024-04-17 11:31:35: New connection from 172.30.32.2:53958 on port 1883.
2024-04-17 11:31:35: Client <unknown> closed its connection.
2024-04-17 11:33:35: New connection from 172.30.32.2:49986 on port 1883.
2024-04-17 11:33:35: Client <unknown> closed its connection.
2024-04-17 11:35:35: New connection from 172.30.32.2:59346 on port 1883.
2024-04-17 11:35:35: Client <unknown> closed its connection.
2024-04-17 11:37:35: New connection from 172.30.32.2:35944 on port 1883.
2024-04-17 11:37:35: Client <unknown> closed its connection.
2024-04-17 11:39:35: New connection from 172.30.32.2:51320 on port 1883.
2024-04-17 11:39:35: Client <unknown> closed its connection.
2024-04-17 11:41:35: New connection from 172.30.32.2:36956 on port 1883.
2024-04-17 11:41:35: Client <unknown> closed its connection.
2024-04-17 11:43:35: New connection from 172.30.32.2:39438 on port 1883.
2024-04-17 11:43:35: Client <unknown> closed its connection.
2024-04-17 11:45:35: New connection from 172.30.32.2:50302 on port 1883.
2024-04-17 11:45:35: Client <unknown> closed its connection.
2024-04-17 11:47:35: New connection from 172.30.32.2:56678 on port 1883.
2024-04-17 11:47:35: Client <unknown> closed its connection.
2024-04-17 11:49:35: New connection from 172.30.32.2:39908 on port 1883.
2024-04-17 11:49:36: Client <unknown> closed its connection.
2024-04-17 11:50:47: New connection from 172.30.33.2:36586 on port 1883.
2024-04-17 11:50:50: New client connected from 172.30.33.2:36586 as mqttjs_dc65ecf3 (p2, c1, k60, u'mqtt').
2024-04-17 11:51:01: Saving in-memory database to /data//mosquitto.db.
2024-04-17 11:51:36: New connection from 172.30.32.2:33168 on port 1883.
2024-04-17 11:51:36: Client <unknown> closed its connection.
2024-04-17 11:53:36: New connection from 172.30.32.2:37192 on port 1883.
2024-04-17 11:53:36: Client <unknown> closed its connection.
2024-04-17 11:55:36: New connection from 172.30.32.2:38896 on port 1883.
2024-04-17 11:55:37: Client <unknown> closed its connection.
2024-04-17 11:57:36: New connection from 172.30.32.2:58036 on port 1883.
2024-04-17 11:57:36: Client <unknown> closed its connection.
2024-04-17 11:59:36: New connection from 172.30.32.2:38036 on port 1883.
2024-04-17 11:59:37: Client <unknown> closed its connection.
