Well this is another kind of error.
This morning my zigbee2mqtt have a bad gateway,
I tried to look into the log and does not seems to find any error.
Here is the log:
Zigbee2MQTT:info 2023-01-24 08:17:51: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-01-24 08:17:51: Coordinator firmware version: ‘{“meta”:{“maintrel”:1,“majorrel”:2,“minorrel”:7,“product”:1,“revision”:20220219,“transportrev”:2},“type”:“zStack3x0”}’
Zigbee2MQTT:info 2023-01-24 08:17:51: Currently 95 devices are joined:
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Toilet and Kitchen Fan (0xbc33acfffefe3319): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Back Alley and Kitchen Light (0xbc33acfffefe32fe): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Kitchen - Air Fryer (0x0c4314fffe9ade32): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Kitchen - Stove Area PIR (0xb4e3f9fffec1f377): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Kitchen - Temperature and Humidity Sensor (0x60a423fffe3cbba1): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Kitchen - Washing Machine PIR (0x8cf681fffe1fef35): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Toilet PIR (0xb4e3f9fffec738ee): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Toilet PIR (Study Room) (0x847127fffe7a0ecb): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Toilet PIR (Bar Area) (0x847127fffe7a0e92): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Temperature and Humidity Sensor (0x60a423fffe3cbb94): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Cabinet PIR (0x8cf681fffe1fefe0): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - PIR 2 (0xb4e3f9fffec73909): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Steamer (0x0c4314fffe9add76): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Rice Cooker (0xa4c1384e2d01e583): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Coffee Machine (0x0c4314fffe9e8c90): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Microwave (0xa4c1383e2be31333): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Oven (0xa4c13865498647a0): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - PIR 1 (0xb4e3f9fffec73965): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Light and Fan (0x2c1165fffe969fa2): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Jing Wen Table (0x00124b0022fe37ad): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Khian Lee Table (0x00124b0022fe4211): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Mi Stick (0x00124b0022fe35f4): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - TV (0x00124b0022fe2fb2): SA-003-Zigbee - eWeLink Zigbee smart plug (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Printer (0x84fd27fffed9cdcb): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Fan (0x60a423fffe8a49da): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Light and Island (0xbc33acfffeae8b24): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Cabinet T5 (0x60a423fffe8a4607): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Air Con Contact (0xa4c13879f3e7d01c): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Store Room - Door Contact (0xa4c1386eed686d5c): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Store Room - Light (0x842e14fffe9c0937): TS0013 - TuYa Smart light switch - 3 gang without neutral wire (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Wooden Door Contact (0xec1bbdfffe3c4ac8): SNTZ007 - TuYa Rechargeable Zigbee contact sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Grille Door Contact (0xa4c1386a7278df04): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: 0x60a423fffe94c434 (0x60a423fffe94c434): TS0013 - TuYa Smart light switch - 3 gang without neutral wire (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Temperature and Humidity Sensor (0x5c0272fffef17882): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - T5 and Eye Ball (0x60a423fffe532a4b): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Fan (0x60a423fffec2037f): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Light (0x60a423fffe53018a): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Air Con Contact (0x00158d0005be758b): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Dehumidifier (0xa4c1387963df7082): WHD02 - TuYa Wall switch module (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Charging Port (0xa4c1387d0138c300): WHD02 - TuYa Wall switch module (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Staircase - Living Room PIR (0x0c4314fffe03c348): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Staircase - Family Hall PIR (0x0c4314fffe56b5b2): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Staircase - Light (0x60a423fffe8a49a0): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Family Hall - Pump (0xa4c138999f1de82a): TS0001 - TuYa 1 gang switch (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Family Hall - Light (0x60a423fffe52f717): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Family Hall - PIR (0x0c4314fffeab25bf): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Extender (0x8cf681fffec5be2a): TS0207_repeater - TuYa Repeater (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Light and Fan (0x60a423fffe53043d): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Toilet (0x60a423fffe8a49a6): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Air Con Contact (0xa4c1380407c8d116): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Temperature and Humidity Sensor (0xec1bbdfffe95903c): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Toilet PIR (0xb4e3f9fffec1ed8b): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (R) - Door Contact (0xec1bbdfffe3c490d): SNTZ007 - TuYa Rechargeable Zigbee contact sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Light and Fan (0xbc33acfffeae8afd): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Door Contact (0xa4c138881976a354): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Extender (0x8cf681fffec5bdf6): TS0207_repeater - TuYa Repeater (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Temperature and Humidity Sensor (0xec1bbdfffe958a30): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Toilet (0x60a423fffe8a49a9): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Toilet PIR (0x8cf681fffe1afbf8): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bedroom (L) - Air Con Contact (0xa4c138a2b2d7c74e): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Mezzanine - Light and Fan (0x60a423fffefbd0da): TS0013 - TuYa Smart light switch - 3 gang without neutral wire (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Family Hall - Temperature and Humidity Sensor (0x847127fffef4e82d): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Mezzanine - Air Con Contact (0xa4c1388a4f2511dc): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Mezzanine - Temperature and Humidity Sensor (0x60a423fffe3c6f3b): TT001ZAV20 - TuYa Temperature & humidity sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Family Hall - Vacuum (0xa4c1388f3b8e7624): ZIGBEE-B09-UK - Zemismart Zigbee smart outlet universal socket with USB port (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Family Hall - Fan (0x0c4314fffe5d96e2): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Door Contact (0x00158d0005be8735): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Extender (0x8cf681fffec865da): TS0207_repeater - TuYa Repeater (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Door PIR (0xb4e3f9fffec73da5): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Wardobe Door Contact (0x00158d0005be766a): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Temperature and Humidity Sensor (0x847127fffef4e92b): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Light and Fan (0x60a423fffe530271): TS0012 - TuYa Smart light switch - 2 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Dehumidifer (0xb4e3f9fffe20707c): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Khian Lee Bedside (0x60a423fffe52f6d2): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Wardrobe Light (0x60a423fffe52f6e8): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Jing Wen Bedside (0x60a423fffe52f6a9): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Toilet (0x60a423fffe8a49ca): TS0011 - TuYa Smart light switch - 1 gang (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Toilet Door PIR (0x0c4314fffea7ed2a): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Air Con Contact (0x00158d00059960e3): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Toilet PIR (0xb4e3f9fffec73957): RH3040 - TuYa PIR sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Water Leak Sensor (0xa4c138937a368501): TS0207_water_leak_detector - TuYa Water leak detector (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Masterbedroom - Shower (0xa4c13838f54eff8f): WHD02 - TuYa Wall switch module (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Water Leak Seonsor (0xa4c1380419e9f4d9): TS0207_water_leak_detector - TuYa Water leak detector (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Khian Lee Universal Switch (0x84fd27fffe803592): TS004F - TuYa Wireless switch with 4 buttons (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Jing Wen Universal Switch (0x84fd27fffe8035e4): TS004F - TuYa Wireless switch with 4 buttons (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Bar Area - Universal Switch (0x60a423fffed5c29b): TS004F - TuYa Wireless switch with 4 buttons (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Universal Switch (0x60a423fffefbcf43): TS0044 - TuYa Wireless switch with 4 buttons (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Living Room - Autogate (0x00124b0022676b9e): E220-KR4N0Z0-HA - TuYa Multiprise with 4 AC outlets and 2 USB super charging ports (16A) (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Garage - Extender (0x8cf681fffec86704): TS0207_repeater - TuYa Repeater (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Garage - Gate Contact 1 (0xa4c138fc792f973d): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Garage - Gate Contact 2 (0xa4c138e6f9ecde3e): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Garage - Hydrophonic (0xa4c13838485c738a): WHD02 - TuYa Wall switch module (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Garage - Gardening (0xa4c13823347c80a6): TS0001 - TuYa 1 gang switch (Router)
Zigbee2MQTT:info 2023-01-24 08:17:51: Garage - Pump Switch (0xb4e3f9fffe3597d3): TS0041 - TuYa Wireless switch with 1 button (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Study Room - Temeperature and Humidity Sensor (0x847127fffefe7cc7): LCZ030 - TuYa Temperature & humidity & illuminance sensor with display (EndDevice)
Zigbee2MQTT:info 2023-01-24 08:17:51: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-01-24 08:17:51: Connecting to MQTT server at mqtt://192.168.50.53:1883
After a few restart also nothing improved. Is getting worse compared to yesterday
