Zigbee2MQTT Crash
Hi all,
I has been facing crashing on my zigbee2mqtt every once 5-8 time per 12 hours. By mean of the crashing, after a few hours, from the look of the Lovelace dashboard everything look fines, however there will be no responses. But when I click the zigbee2mqtt from the side bar, nothings happens. When I check on the log, nothing unusual. It requires me to restart the zigbee2mqtt to make it workable again.
Anyone facing this kind of issue before? This only recently happened to me.
For your info, been using raspberry pi 4b and sonoff dongle 3.0
I had already reformat and reinstall all as new but still it happens.
Check the zigbee2mqtt addon log.
Hi. Thanks for reply
I had check nothing unusual. Here is the log
Zigbee2MQTT:info 2023-01-21 11:24:44: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:24:44.446Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:24:47: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Coffee Machine’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:407.67,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:24:47.117Z”,“linkquality”:61,“power”:0,“power_outage_memory”:“on”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:24:52: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:24:52.513Z”,“linkquality”:98,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:24:53: MQTT publish: topic ‘zigbee2mqtt/Bedroom (L) - Extender’, payload ‘{“last_seen”:“2023-01-21T03:24:53.781Z”,“linkquality”:58}’
Zigbee2MQTT:info 2023-01-21 11:24:54: MQTT publish: topic ‘zigbee2mqtt/Kitchen - Air Fryer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:9.37,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:24:54.175Z”,“linkquality”:47,“power”:0,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:00: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:00.584Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:25:02: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Vacuum’, payload ‘{“last_seen”:“2023-01-21T03:25:02.587Z”,“linkquality”:61,“power_outage_memory”:null,“state_l1”:“ON”,“state_l2”:“ON”}’
Zigbee2MQTT:info 2023-01-21 11:25:03: MQTT publish: topic ‘zigbee2mqtt/Kitchen - Air Fryer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:9.37,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:03.722Z”,“linkquality”:47,“power”:0,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:04: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Coffee Machine’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:407.67,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:04.563Z”,“linkquality”:61,“power”:0,“power_outage_memory”:“on”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:25:04: MQTT publish: topic ‘zigbee2mqtt/Study Room - Printer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:5.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:04.587Z”,“linkquality”:94,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:25:05: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Fan’, payload ‘{“child_lock”:“UNLOCK”,“current”:0.15,“energy”:58.65,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:05.917Z”,“linkquality”:65,“power”:33,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:08: MQTT publish: topic ‘zigbee2mqtt/Masterbedroom - Dehumidifer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:288.7,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:08.534Z”,“linkquality”:29,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:25:08: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:08.644Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:25:10: MQTT publish: topic ‘zigbee2mqtt/Masterbedroom - Dehumidifer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:288.7,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:10.924Z”,“linkquality”:29,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:25:13: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Fan’, payload ‘{“child_lock”:“UNLOCK”,“current”:0.15,“energy”:58.65,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:13.905Z”,“linkquality”:83,“power”:33,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:16: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:16.710Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:25:18: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Steamer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:118.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:18.070Z”,“linkquality”:80,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:20: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Fan’, payload ‘{“child_lock”:“UNLOCK”,“current”:0.15,“energy”:58.65,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:20.334Z”,“linkquality”:65,“power”:33,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:21: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Oven’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:0.1,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:21.598Z”,“linkquality”:94,“power”:0,“power_outage_memory”:“restore”,“state”:“OFF”,“update”:{“installed_version”:192,“latest_version”:192,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:21: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Oven’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:0.1,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:21.682Z”,“linkquality”:94,“power”:0,“power_outage_memory”:“restore”,“state”:“OFF”,“update”:{“installed_version”:192,“latest_version”:192,“state”:“idle”},“update_available”:null,“voltage”:243}’
Zigbee2MQTT:info 2023-01-21 11:25:24: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:24.783Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:warn 2023-01-21 11:25:29: Failed to ping ‘Bar Area - Light and Island’ (attempt 1/1, Read 0xbc33acfffeae8b24/1 genBasic([“zclVersion”], {“sendWhen”:“immediate”,“timeout”:10000,“disableResponse”:false,“disableRecovery”:true,“disableDefaultResponse”:true,“direction”:0,“srcEndpoint”:null,“reservedBits”:0,“manufacturerCode”:null,“transactionSequenceNumber”:null,“writeUndiv”:false}) failed (Data request failed with error: ‘MAC transaction expired’ (240)))
Zigbee2MQTT:info 2023-01-21 11:25:32: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:32.857Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:25:34: MQTT publish: topic ‘zigbee2mqtt/Bedroom (R) - Light and Fan’, payload ‘{“backlight_mode”:null,“last_seen”:“2023-01-21T03:25:34.174Z”,“linkquality”:40,“power_on_behavior”:null,“state_left”:“OFF”,“state_right”:“ON”}’
Zigbee2MQTT:info 2023-01-21 11:25:34: MQTT publish: topic ‘zigbee2mqtt/Bedroom (R) - Light and Fan/mode’, payload ‘{“backlight”:null}’
Zigbee2MQTT:info 2023-01-21 11:25:36: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Toilet and Kitchen Fan’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-21T03:25:36.371Z”,“linkquality”:72,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:36: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Toilet and Kitchen Fan/mode’, payload ‘{“backlight”:“normal”}’
Zigbee2MQTT:info 2023-01-21 11:25:39: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Steamer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:118.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:25:39.189Z”,“linkquality”:80,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - Mi Stick’, payload ‘{“last_seen”:“2023-01-21T03:25:40.329Z”,“linkquality”:51,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - Mi Stick’, payload ‘{“last_seen”:“2023-01-21T03:25:40.338Z”,“linkquality”:51,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - Mi Stick’, payload ‘{“last_seen”:“2023-01-21T03:25:40.348Z”,“linkquality”:51,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - Mi Stick’, payload ‘{“last_seen”:“2023-01-21T03:25:40.364Z”,“linkquality”:51,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - Mi Stick’, payload ‘{“last_seen”:“2023-01-21T03:25:40.386Z”,“linkquality”:51,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - TV’, payload ‘{“last_seen”:“2023-01-21T03:25:40.513Z”,“linkquality”:54,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - TV’, payload ‘{“last_seen”:“2023-01-21T03:25:40.526Z”,“linkquality”:54,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - TV’, payload ‘{“last_seen”:“2023-01-21T03:25:40.538Z”,“linkquality”:54,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - TV’, payload ‘{“last_seen”:“2023-01-21T03:25:40.556Z”,“linkquality”:54,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - TV’, payload ‘{“last_seen”:“2023-01-21T03:25:40.571Z”,“linkquality”:54,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:25:40: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:40.918Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:25:49: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:49.044Z”,“linkquality”:61,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:25:53: MQTT publish: topic ‘zigbee2mqtt/Living Room - Dehumidifier’, payload ‘{“last_seen”:“2023-01-21T03:25:53.268Z”,“linkquality”:134,“power_on_behavior”:“previous”,“state”:“OFF”,“switch_type”:“toggle”}’
Zigbee2MQTT:info 2023-01-21 11:25:57: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:25:57.069Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:03: MQTT publish: topic ‘zigbee2mqtt/Kitchen - Air Fryer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:9.37,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:03.870Z”,“linkquality”:47,“power”:0,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:04: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Coffee Machine’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:407.67,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:04.677Z”,“linkquality”:61,“power”:0,“power_outage_memory”:“on”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:04: MQTT publish: topic ‘zigbee2mqtt/Study Room - Printer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:5.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:04.702Z”,“linkquality”:94,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:05: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:26:05.114Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:08: MQTT publish: topic ‘zigbee2mqtt/Bedroom (R) - Extender’, payload ‘{“last_seen”:“2023-01-21T03:26:08.459Z”,“linkquality”:58}’
Zigbee2MQTT:info 2023-01-21 11:26:08: MQTT publish: topic ‘zigbee2mqtt/Masterbedroom - Dehumidifer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:288.7,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:08.682Z”,“linkquality”:58,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:26:09: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Coffee Machine’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:407.67,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:09.040Z”,“linkquality”:83,“power”:0,“power_outage_memory”:“on”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:13: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:26:13.193Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:14: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Rice Cooker’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:3.43,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:14.128Z”,“linkquality”:76,“power”:0,“power_outage_memory”:“restore”,“state”:“OFF”,“update”:{“installed_version”:192,“latest_version”:192,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:26:15: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Pump’, payload ‘{“last_seen”:“2023-01-21T03:26:15.557Z”,“linkquality”:40,“power_on_behavior”:null,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:15: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Pump’, payload ‘{“last_seen”:“2023-01-21T03:26:15.627Z”,“linkquality”:40,“power_on_behavior”:null,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:15: MQTT publish: topic ‘zigbee2mqtt/Study Room - Jing Wen Table’, payload ‘{“last_seen”:“2023-01-21T03:26:15.854Z”,“linkquality”:94,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:15: MQTT publish: topic ‘zigbee2mqtt/Study Room - Jing Wen Table’, payload ‘{“last_seen”:“2023-01-21T03:26:15.870Z”,“linkquality”:94,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:15: MQTT publish: topic ‘zigbee2mqtt/Study Room - Jing Wen Table’, payload ‘{“last_seen”:“2023-01-21T03:26:15.885Z”,“linkquality”:94,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:15: MQTT publish: topic ‘zigbee2mqtt/Study Room - Jing Wen Table’, payload ‘{“last_seen”:“2023-01-21T03:26:15.910Z”,“linkquality”:94,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:18: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Steamer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:118.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:18.205Z”,“linkquality”:80,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:20: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Fan’, payload ‘{“child_lock”:“UNLOCK”,“current”:0.15,“energy”:58.65,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:20.460Z”,“linkquality”:94,“power”:33,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:26:21: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:26:21.250Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:27: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Oven’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:0.1,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:27.341Z”,“linkquality”:61,“power”:0,“power_outage_memory”:“restore”,“state”:“OFF”,“update”:{“installed_version”:192,“latest_version”:192,“state”:“idle”},“update_available”:null,“voltage”:243}’
Zigbee2MQTT:info 2023-01-21 11:26:29: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Steamer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:118.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:29.167Z”,“linkquality”:80,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:29: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:26:29.319Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:31: MQTT publish: topic ‘zigbee2mqtt/Garage - Gardening’, payload ‘{“last_seen”:“2023-01-21T03:26:31.362Z”,“linkquality”:54,“power_on_behavior”:“previous”,“state”:“OFF”}’
Zigbee2MQTT:info 2023-01-21 11:26:35: MQTT publish: topic ‘zigbee2mqtt/Masterbedroom - Dehumidifer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:288.7,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:35.158Z”,“linkquality”:40,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:26:37: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:26:37.406Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:37: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Rice Cooker’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:3.43,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:37.612Z”,“linkquality”:72,“power”:0,“power_outage_memory”:“restore”,“state”:“OFF”,“update”:{“installed_version”:192,“latest_version”:192,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-21 11:26:39: MQTT publish: topic ‘zigbee2mqtt/Study Room - Printer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:5.4,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:39.064Z”,“linkquality”:120,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:241}’
Zigbee2MQTT:info 2023-01-21 11:26:40: MQTT publish: topic ‘zigbee2mqtt/Garage - Extender’, payload ‘{“last_seen”:“2023-01-21T03:26:40.940Z”,“linkquality”:105}’
Zigbee2MQTT:info 2023-01-21 11:26:42: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Microwave’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:3.61,“indicator_mode”:“off/on”,“last_seen”:“2023-01-21T03:26:42.028Z”,“linkquality”:83,“power”:0,“power_outage_memory”:“restore”,“state”:“OFF”,“update”:{“installed_version”:192,“latest_version”:192,“state”:“idle”},“update_available”:null,“voltage”:243}’
Zigbee2MQTT:info 2023-01-21 11:26:45: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:71.1,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-21T03:26:45.453Z”,“linkquality”:94,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-21 11:26:45: MQTT publish: topic ‘zigbee2mqtt/Living Room - Charging Port’, payload ‘{“last_seen”:“2023-01-21T03:26:45.831Z”,“linkquality”:105,“power_on_behavior”:“previous”,“state”:“OFF”,“switch_type”:“toggle”}’
You need to check the log when it is not working.
Hi. I had check thru when the log when it is not working. Still the same as what I posted. 😵‍💫
Running 1.29.1 ?
Hi.
Currently I am running 1.29.2-1
Every morning this will happened to me
And this is the log
Zigbee2MQTT:info 2023-01-22 08:15:44: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:44.839Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:44: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light/mode’, payload ‘{“backlight”:“normal”}’
Zigbee2MQTT:info 2023-01-22 08:15:44: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:44.858Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:44: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:44.972Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:44: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:44.976Z”,“linkquality”:98,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Masterbedroom - Dehumidifer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:288.84,“indicator_mode”:“off/on”,“last_seen”:“2023-01-22T00:15:45.250Z”,“linkquality”:65,“power”:0,“power_outage_memory”:“off”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:245}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:45.586Z”,“linkquality”:98,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light/mode’, payload ‘{“backlight”:“normal”}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:45.591Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:45.794Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:45.915Z”,“linkquality”:102,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:45: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:45.919Z”,“linkquality”:91,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:46: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:46.153Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:46: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light/mode’, payload ‘{“backlight”:“normal”}’
Zigbee2MQTT:info 2023-01-22 08:15:46: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:46.156Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:48: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:48.155Z”,“linkquality”:98,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:15:48: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light/mode’, payload ‘{“backlight”:“normal”}’
Zigbee2MQTT:info 2023-01-22 08:15:48: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:15:48.158Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:16:04: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:16:04.988Z”,“linkquality”:94,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:16:05: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:57.6,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-22T00:16:05.455Z”,“linkquality”:36,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-22 08:16:05: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Vacuum’, payload ‘{“last_seen”:“2023-01-22T00:16:05.463Z”,“linkquality”:76,“power_outage_memory”:null,“state_l1”:“ON”,“state_l2”:“ON”}’
Zigbee2MQTT:info 2023-01-22 08:16:05: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light/mode’, payload ‘{“backlight”:“normal”}’
Zigbee2MQTT:info 2023-01-22 08:16:05: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Back Alley and Kitchen Light’, payload ‘{“backlight_mode”:“normal”,“last_seen”:“2023-01-22T00:16:04.992Z”,“linkquality”:98,“power_on_behavior”:null,“power_on_behavior_left”:“previous”,“state_left”:“OFF”,“state_right”:“OFF”}’
Zigbee2MQTT:info 2023-01-22 08:17:42: MQTT publish: topic ‘zigbee2mqtt/Family Hall - Vacuum’, payload ‘{“last_seen”:“2023-01-22T00:17:41.013Z”,“linkquality”:76,“power_outage_memory”:null,“state_l1”:“ON”,“state_l2”:“ON”}’
Zigbee2MQTT:info 2023-01-22 08:17:42: MQTT publish: topic ‘zigbee2mqtt/Bar Area - Coffee Machine’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:407.67,“indicator_mode”:“off/on”,“last_seen”:“2023-01-22T00:17:42.420Z”,“linkquality”:116,“power”:0,“power_outage_memory”:“on”,“state”:“OFF”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-22 08:17:42: MQTT publish: topic ‘zigbee2mqtt/Kitchen - Air Fryer’, payload ‘{“child_lock”:“UNLOCK”,“current”:0,“energy”:10.34,“indicator_mode”:“off/on”,“last_seen”:“2023-01-22T00:17:42.448Z”,“linkquality”:58,“power”:0,“power_outage_memory”:“off”,“state”:“ON”,“update”:{“installed_version”:-1,“latest_version”:-1,“state”:“idle”},“update_available”:null,“voltage”:242}’
Zigbee2MQTT:info 2023-01-22 08:17:42: MQTT publish: topic ‘zigbee2mqtt/Study Room - Temeperature and Humidity Sensor’, payload ‘{“alarm_humidity”:“off”,“alarm_humidity_max”:100,“alarm_humidity_min”:20,“alarm_temperature”:“off”,“alarm_temperature_max”:40,“alarm_temperature_min”:10,“battery”:100,“humidity”:57.6,“illuminance”:0,“illuminance_lux”:0,“last_seen”:“2023-01-22T00:17:42.446Z”,“linkquality”:54,“temperature”:29.8,“voltage”:3000}’
Zigbee2MQTT:info 2023-01-22 08:17:42: MQTT publish: topic ‘zigbee2mqtt/Garage - Hydrophonic’, payload ‘{“last_seen”:“2023-01-22T00:17:42.907Z”,“linkquality”:7,“power_on_behavior”:“previous”,“state”:“ON”,“switch_type”:“toggle”}’
That log suggests there is nothing wrong with zigbee2mqtt.
Use MQTTExplorer (http://mqtt-explorer.com/) to check that the messages are being received by your mqtt broker.
If this is the case then your problem is the connection of Home Assistant to the Broker.
Sorry cause i am quite new to MQTTExplorer. Any guide to check the connection?
BTW I discovered that ever since updated to 1.29 version, this things keep on happening.
:sob:
  • Install mqtt explorer on a PC.
  • Run it.
  • Enter the ip address of your mqtt broker (home assistant IP address if using the mqtt addon) in the “host” section.
  • Click the Connect button.
  • Look at the topics in the left hand column.
  • Find the topic for one of your devices. you can expand it to show the message.
  • When the state changes it should flash.
Meaning need to be constantly monitoring? There won’t be any method to check on the log?
Or is there anyway to roll back to 1.28? I thought my HA have issue so I had to aclean set up.
No not constantly. As soon as you notice it has failed in home assistant check the broker. You can open and close contact sensors or switch lights so that messages are sent.
It happens again this morning, however this morning, when everything has become unavailable, after a few minutes around 30 mins, they connection is back. But when everything is back, HA is started to delay. The switch that had been pressed is not responded instantaneously. What do you think is lost connection during that period of time?
Did you check if messages were being received at the broker at that time?
The message did receive at the broker at that time
Do you monitor your system CPU and memory?
Probably related. Zigbee2MQTT had bug: Update 1.29.0.1 - big problem: Front end not loading, devices not working > wife mad · Issue #15856 · Koenkk/zigbee2mqtt · GitHub
Just released version 1.29.2-1 fixes that.
Any idea what’s wrong with my HA?
