Zigbee2MQTT Crashing all the time (ZB-DONGLEE/PI5)
I am frequently getting ROUTE_ERROR messages in Z2M but nothing goes completely wrong and devices are controllable reliably, but when you basically try to configure anything (thats what is feels like at least) like running an OTA Update the error messages pile up and it eventually crashes. I am running a Raspberry Pi 5 4GB with a SONOFF Dongle-E Plus, I tried with and without a usb 3 extension, usb 2/3 ports, powered usb hub (didnt work at all, couldnt find and device id to use) but nothing worked, I initially had the error on EMBER Firmware for the dongle-e, but I temporarily switched to ezsp in hopes of that working, no luck. I also carefully went over the config.yaml over and over again to make sure it was correct, correct hardware path, no hardware flow control, etc. but nothing helps.
I attached the part of the log when the crash occured (In this case it was the ikea.airquality that i tried to OTA, but happens with all of them), the config and the zigbee map as it may be useful
Thanks in advance!
