One question about this module… can it be used with physical switch that remain in the position? I don’t know exactly the vocabulary…
I want to say, there are switch that when you press it and release, they return to the initial position. Others remain fixed.
In the videos that I’ve seen testing this, all of them use switch that return to the initial position. Can be used with the others too?
I think you’re looking for the word “latching”, i.e. a button that latches / stays in the position.
Else the ones which are only press and release are called “momentary”.
Thank you! I was freaking out with mqtt commands and came up with his comment. i did these steps:
Activate calibration mode
Open the shutter completely and press stop
Set the number to 100 and press the refresh button
Close the shutter completely and when it comes to an end, press STOP.
Set the position to 0, press the refresh button and deactivate the calibration.
I had to add an extra 3 seconds because the motor takes 3 more seconds to fully climb due to the weight. So when it goes down it stays on for an extra 3 seconds but goes up all the way.
(There is no problem because the start and end of travel are configured in the motor).
My Zigbee2mqtt module QS-Zigbee-C01 is wrongly detected as Tuya TS130F. Is there any way that I can fix this? I have tried repair but result is the same.
just to report my HA tests. So with ZHA, I’ve tried in “cluster” mode in the entity to set calibration mode and set the shutter time to more than 10 seconds (default value). But nothing good with ZHA, if anyone had succeeded, let me know.
Then I’ve removed ZHA and installed Z2M and then it’s ok with the webUI : set calibration mode ON, open the shutter to the max, Stop, close completely and stop again, then set calibration mode OFF.
And voilà !
I’m trying to replace Nice TT2N that currently control my rolling shutters. The problem is that I have only one physical push button which does up-stop-down-stop. Here is the schematic for TT2N:
So I have only one wire going from the push button to the controller.
Anyone knows if QS-Zigbee-C01-LN supports that mode?
This is very simple. Open the calibration mode to “ON”. And then position 100, wait the blind up to stop. Then position 0, wait the blind down to stop. Then close the calibration mode “OFF”. You will find your module has remembered what you set. Good luck!
I had the same issue with my curtain module.
My motor takes more time to go up.
Do you know if there is a way to fix it ?
For me it’s an issue because when the shutter is completely open and you need to close it (around 50%) and then you try to open it completely the shutter will not be fully open.
I found this : Custom Component: Cover Time Based
I don’t know if this custom component is able to do what I want. (I copy paste the conf but it’s not working for me. Maybe I need to create additional scripts ?).
Hi @Eden91, did you manage to fix it? My roller shutter also takes more time to lift, and my Zigbee switch only allows to configure one calibration time, so every time I open the roller shutter, it won’t close completely.
Did you try the “Cover time based” custom component? did it work as you expected?
Still no solution for this problem ?
It will be great to set time to go up and a time to go down.
Don’t know if a new motor is able to have the same time to go up and down?
I think you can do this with another relay paralell with the tt2n controlling the down and up connection of the motor. this way you could keep the current controller with the remote and use home assistant on top through for example a zigbee relay. You can maybe even send directly up down commands to the TT2N since it is a 433Mhz radio signal. Maybe a broadlink rm4 pro works to copy the radio signal commands? Did you try meanwhile?
