It seems the automation is not running.
Try to start it manually via the automation page. I had this error for a long time after the HA restarts. After the restart, the error is gone and the automation works.
After doing a new edit of the script.noop according the instructions, the error seems to be gone… but I have to recheck…
Greets Nobbb
“Radiator covered” does not work at all. The thermostat opens as it should and the temperature is also updated and sent to the thermostat. But the thermostat never closes.
EDIT: script.noop was the problem ![]()
But I get these errors after restarting Home Assistant
Logger: homeassistant.components.automation.ally_kontor
Source: helpers/script.py:2032
integration: Automation (documentation, issues)
First occurred: 20:08:16 (1 occurrences)
Last logged: 20:08:16
Ally (Ext Temp) Kontor: Error executing script. Invalid data for call_service at pos 2: offset script.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noop should be format 'HH:MM', 'HH:MM:SS' or 'HH:MM:SS.F' for dictionary value @ data['duration']
Source: components/automation/__init__.py:764
Error while executing automation automation.ally_kontor: offset script.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noopscript.noop should be format 'HH:MM', 'HH:MM:SS' or 'HH:MM:SS.F' for dictionary value @ data['duration']
This happens because at startup radiator_covered_state is not available.
max_update_minutes: |
{% if radiator_covered_state == 'off' %}
180
{% elif radiator_covered_state == 'on' %}
30
{% else %}
script.noop
{% endif %}
The script wants to start timer with duration of "script.noop" * 60 which is string and will not obviously work. Not sure does the duration set ever work if radiator_covered_state is not available or is this just startup issue. Probably after startup radiator_covered_state is available and this doesn’t show up after that.
- service: timer.start
entity_id: !input max_update_timer_id
duration: "{{ max_update_minutes * 60 }}"
Hello!
I’ve been using your BP for quite some time. However since last update it has stopped working with the following trace error:
Fel: extra keys not allowed @ data[‘payload_template’]
How would i go about to fix this issue?
Currently none of my thermostats get an updated temperature due to this error.
Since update 2024.8 I noticed, that the payload_template parameter of MQTT publish will be deprecated in 2025.2.0.
To make it work again, change it to payload: in blueprint.
this part
- service: mqtt.publish
topic: >-
zigbee2mqtt/{{ device_attr(device, 'name')
}}/set/external_measured_room_sensor
payload: '{{ (states(temp_sensor_id) | float * 100) | round(0) }}'
Thank you! this solved my problem
Ally has normally 0,5C steps in setting target temperature and 0,5C hysteresis. With external_measured_room_sensor you can set the target temperature with 0.1C or 0.01C steps. How?
I have separate input_number that I use to set target temperature in 0.1C steps. Then I use the 0.5C accuracy to set the actual thermostat target temperature. The difference, the 0.1C accuracy part I subtract from value sent to external_measured_room_sensor. Then the thermostat operates in 0.1C target temperature accuracy.
I could also make the 0,5C hysteresis to half.
Because I control what temperature thermostat is given, I can double the temp difference of actual temp and target temp. Then thermostat starts to act with 0,25C hysteresis. Basically:
informed_temp = ( actual_temp - target_temp) * 2 + target_temp
I don’t use fixed 2, but input_number so I can find the best value.
With value 1.6, when sun was shining and went down, getting the temps back to normal level took 3hrs earlier, now 2 hours.
