i updated the blueprint from @napalm to update danfoss ally valves with external temperature sensors over zigbee2mqqt. This version does not need any timers anymore and will update according to radiator mode minimum interval, 5 minutes for covered, 30 minutes for uncovered AND temperature change above 0.1K OR 30 minutes for covered, 180 minutes for uncovered).
I have been using this for some days now. and I have an issue.
I the them sensor have not changed for 3 hours, it does not refresh the value “External measured room sensor”, so after 3 hours, the TRV resets to -8000
Hello, i had the same issue with one of my TRV´s (i have 15 of them at my house) also. I had set radiator covered to “true”. I think this problem occured, because i rebooted home assistant and the 30 (35 to -8000 value) minutes timer was close the set the next action again. Because then it was not triggered it was set to radiator uncovered by itself then. Maybe that could be the issue for you also?
I cant reproduce it actually. It works for 15 TRV´s without any problem for now. Do you also run the thermostats in covered mode? Because if i look at your screeshot, there are 2 hours difference from 11:25h to 13:25h which seems to be uncovered mode. Later then, we see 15 minutes difference, which seems to be covered mode. A second idea could be, that maybe the connection is not the best and maybe you have some packetloss?
I have same issue. As long as the temperature does not change script stops sending the temperature and Danfoss Ally cancel the external temperature input.
Maybe the script is not able to detect “covered mode” correctly in some cases.
For now I modified the script and set fixed values for min/max update time and waiting for results
min_update_minutes: 5
max_update_minutes: 10
I have new version of TRV with “G” before serial number if that matter
Hi, it seems there are indeed sometimes problems with the automation. I had not really seen it. I updated the automation, see below. Please test this one which needs a timer. You also should make a new script.noop with this yaml code:
script.noop:
alias: noop
sequence:
- delay: "00:00:00"
automation-blueprint:
blueprint:
domain: automation
name: Danfoss Ally Ext Temp Z2M v2
description: >
Update Danfoss Ally TRV external temperature with min/max refresh rate, via zigbee2mqtt.
input:
ally_device:
name: Ally TRV Device
description: Temperature reading will be sent to this device.
selector:
device:
entity:
- domain:
- climate
multiple: false
temp_sensor_id:
description: >
External sensor from which the temperature will be read. Expects data format 12.3.
selector:
entity:
domain:
- sensor
device_class:
- temperature
multiple: false
max_update_timer_id:
description: >
Timer that will trigger at maximum update interval if source sensor has not
changed. Sets automatically to 30min for covered, 3h for uncovered. Use separate
timer for each automation.
selector:
entity:
domain:
- timer
multiple: false
variables:
device: !input ally_device
temp_sensor_id: !input temp_sensor_id
radiator_covered_state: >
{{ states( device_entities(device) | select('match', '.*radiator_covered$')
| first) }}
min_update_minutes: |
{% if radiator_covered_state == 'off' %}
30
{% elif radiator_covered_state == 'on' %}
5
{% else %}
script.noop
{% endif %}
max_update_minutes: |
180
30
{% else %}
script.noop
{% endif %}
- platform: state
entity_id: !input temp_sensor_id
- platform: event
event_type: timer.finished
event_data:
entity_id: !input max_update_timer_id
condition:
- condition: and
conditions:
- condition: template
value_template: "{{ states(temp_sensor_id) is not none }}"
value_template: "{{ states(temp_sensor_id) | float(0) > 0 }}"
- condition: or
conditions:
- condition: and
conditions:
value_template: >-
{% set number_entity = device_entities(device) |
select('search', 'number.*_external_measured_room_sensor') |
list | first %} {{ ((states(number_entity) | float(0) -
states(temp_sensor_id) | float * 100) | round(0)) | abs >=10
value_template: >-
{% set last_trigger = state_attr(this.entity_id,
'last_triggered') %} {{ last_trigger is none or now() -
last_trigger > timedelta(seconds=min_update_minutes * 60) }}
- condition: state
state: idle
- service: mqtt.publish
topic: >-
zigbee2mqtt/{{ device_attr(device, 'name')
}}/set/external_measured_room_sensor
payload_template: '{{ (states(temp_sensor_id) | float * 100) | round(0) }}'
- service: timer.start
duration: '{{ max_update_minutes * 60 }}'
mode: single
max_exceeded: silent
Using the blueprint for a few days now, seems to work as expected (uncovered mode). Thank you for this!!
One thing that is a bit annoying is that the external temperature reported by the Ally (“external_measured_room_sensor”) is not in °C so I cannot plot it against the value of the actual external temperature sensor. Anybody an idea what needs to be changed to get this provided? I think this could be done with some helper/automation, but preferably zigbee2mqtt could provide this out of the box for the Allys (maybe as a separate attribute for backwards compatibility)?
Settings → Automations & Scenes → Scripts → Add Script → Create new script → click on three dots in the top right corner and select YAML editor → paste the code there
Is the value for external_measured_room_sensor in fahrenheit?
The default (aka off) value is -8000 what would be an external temp like 21°C as a value?
Thanks for the Blueprint. I have tested with 2 thermostats for 1 sensor and both in uncovered mode. They also have some load balancing enabled. It works great! The temperature of the external sensor stays close enough to the SP of the thermostat. Doing the period the SP was 16 °C.
Quick question, what will happen if the external sensor becomes unavailable eg. runs out of battery? The External_measured_room_sensor property will be disabled because of no temperature update?
Deprecated payload_template option used in MQTT publish action call to topic zigbee2mqtt/Danfoss spisestue/set/external_measured_room_sensor from payload template 2510 . Use the payload option instead. In automations templates are supported natively. Update the automation or script to use the payload option instead and restart Home Assistant to fix this issue.
