The switch works like this
1st goes down → blinds go down
2nd goes down → blinds go up → the 1. Gets pulled open.
It can be only 1 on at the same time.
But the blinds somehow think I’m using this non rocker switch
And when i switch the 1 to of the blinds go down…
I am asking for pointers where to discuss this problem…
I would program it my self gladly… i want to get involved with the project if there is no fix.
The controller is supporting the change of the switch type:
“Switch (Zigbee)” to add device.And select the right
Gateway to confirm the connection.
Note: Make sure you have successfully connected
one Zigbee gateway hub.
Well, for the beginning, you could sniff the traffic while pairing and attach that to your github problem.
A zigbee-herdsman debug file as always usuable too.
Ye, i don’t see it on pairing mode.
I think it is a setting like the inverted cover, which has to be set via the app over the bridge. I don’t have one. And i dont know how i could sniff a bridge…
