Zigbee2MQTT device dropped on floor, stopped connecting
my Zigbee2MQTT device dropped and the USB connection was slightly pulled apart.
I pushed the USB connection back and Home Assistant isn’t showing the temperature sensor output?
I checked Add Ons and the Zigbee2MQTT hasn’t started?
I manually pressed start, but nothing happens?
Here’s the output from the Zigbee2MQTT Log below which doesn’t help me much?
[2024-09-10 14:20:37] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_office', payload '{"battery":87,"humidity":56.58,"linkquality":96,"temperature":27.37,"voltage":2500}'
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: <-- [254,1,100,1,0,100]
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: --- parseNext [254,1,100,1,0,100]
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: --> parsed 1 - 3 - 4 - 1 - [0] - 100
[2024-09-10 14:20:37] debug: 	zh:zstack:znp: SRSP: <-- AF - dataRequest - {"status":0}
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: --- parseNext []
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: <-- [254,3,68,128,0,1,45,235]
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: --- parseNext [254,3,68,128,0,1,45,235]
[2024-09-10 14:20:37] debug: 	zh:zstack:unpi:parser: --> parsed 3 - 2 - 4 - 128 - [0,1,45] - 235
[2024-09-10 14:20:37] debug: 	zh:zstack:znp: AREQ: <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":45}
[2024-09-10 14:22:34] debug: 	z2m: Saving state to file /config/zigbee2mqtt/state.json
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: <-- [254,28,68,129,0,0,2,4,8,198,1,1,0,87,0,100,176,143,0,0,8,8,116,10,0,0,41,173,10,8,198,29,62]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --- parseNext [254,28,68,129,0,0,2,4,8,198,1,1,0,87,0,100,176,143,0,0,8,8,116,10,0,0,41,173,10,8,198,29,62]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --> parsed 28 - 2 - 4 - 129 - [0,0,2,4,8,198,1,1,0,87,0,100,176,143,0,0,8,8,116,10,0,0,41,173,10,8,198,29] - 62
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: AREQ: <-- AF - incomingMsg - {"groupid":0,"clusterid":1026,"srcaddr":50696,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":87,"securityuse":0,"timestamp":9416804,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,116,10,0,0,41,173,10]}}
[2024-09-10 14:25:44] debug: 	zh:controller: Received payload: clusterID=1026, address=50696, groupID=0, endpoint=1, destinationEndpoint=1, wasBroadcast=false, linkQuality=87, frame={"header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":116,"commandIdentifier":10},"payload":[{"attrId":0,"dataType":41,"attrData":2733}],"command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}}
[2024-09-10 14:25:44] debug: 	zh:controller:endpoint: ZCL command 0xa4c138209e1602bc/1 msTemperatureMeasurement.defaultRsp({"cmdId":10,"statusCode":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"reservedBits":0,"transactionSequenceNumber":116,"writeUndiv":false})
[2024-09-10 14:25:44] debug: 	zh:zstack: sendZclFrameToEndpointInternal 0xa4c138209e1602bc:50696/1 (0,0,1)
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: SREQ: --> AF - dataRequest - {"dstaddr":50696,"destendpoint":1,"srcendpoint":1,"clusterid":1026,"transid":46,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[24,116,11,10,0]}}
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:writer: --> frame [254,15,36,1,8,198,1,1,2,4,46,0,30,5,24,116,11,10,0,186]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --- parseNext []
[2024-09-10 14:25:44] debug: 	z2m: Received Zigbee message from 'temp_office', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2733}' from endpoint 1 with groupID 0
[2024-09-10 14:25:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_office', payload '{"battery":87,"humidity":56.58,"linkquality":87,"temperature":27.33,"voltage":2500}'
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: <-- [254,1,100,1,0,100]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --- parseNext [254,1,100,1,0,100]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --> parsed 1 - 3 - 4 - 1 - [0] - 100
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: SRSP: <-- AF - dataRequest - {"status":0}
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: <-- [254,3,68,128,0,1,46,232]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --- parseNext [254,3,68,128,0,1,46,232]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --> parsed 3 - 2 - 4 - 128 - [0,1,46] - 232
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: AREQ: <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":46}
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: <-- [254,28,68,129,0,0,5,4,8,198,1,1,0,87,0,24,208,143,0,0,8,8,117,10,0,0,33,33,22,8,198,29,188]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --- parseNext [254,28,68,129,0,0,5,4,8,198,1,1,0,87,0,24,208,143,0,0,8,8,117,10,0,0,33,33,22,8,198,29,188]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --> parsed 28 - 2 - 4 - 129 - [0,0,5,4,8,198,1,1,0,87,0,24,208,143,0,0,8,8,117,10,0,0,33,33,22,8,198,29] - 188
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: AREQ: <-- AF - incomingMsg - {"groupid":0,"clusterid":1029,"srcaddr":50696,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":87,"securityuse":0,"timestamp":9424920,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[8,117,10,0,0,33,33,22]}}
[2024-09-10 14:25:44] debug: 	zh:controller: Received payload: clusterID=1029, address=50696, groupID=0, endpoint=1, destinationEndpoint=1, wasBroadcast=false, linkQuality=87, frame={"header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0},"transactionSequenceNumber":117,"commandIdentifier":10},"payload":[{"attrId":0,"dataType":33,"attrData":5665}],"command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}}
[2024-09-10 14:25:44] debug: 	zh:controller:endpoint: ZCL command 0xa4c138209e1602bc/1 msRelativeHumidity.defaultRsp({"cmdId":10,"statusCode":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":1,"reservedBits":0,"transactionSequenceNumber":117,"writeUndiv":false})
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: SREQ: --> AF - dataRequest - {"dstaddr":50696,"destendpoint":1,"srcendpoint":1,"clusterid":1029,"transid":47,"options":0,"radius":30,"len":5,"data":{"type":"Buffer","data":[24,117,11,10,0]}}
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:writer: --> frame [254,15,36,1,8,198,1,1,5,4,47,0,30,5,24,117,11,10,0,189]
[2024-09-10 14:25:44] debug: 	z2m: Received Zigbee message from 'temp_office', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":5665}' from endpoint 1 with groupID 0
[2024-09-10 14:25:44] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/temp_office', payload '{"battery":87,"humidity":56.65,"linkquality":87,"temperature":27.33,"voltage":2500}'
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: <-- [254,3,68,128,0,1,47,233]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --- parseNext [254,3,68,128,0,1,47,233]
[2024-09-10 14:25:44] debug: 	zh:zstack:unpi:parser: --> parsed 3 - 2 - 4 - 128 - [0,1,47] - 233
[2024-09-10 14:25:44] debug: 	zh:zstack:znp: AREQ: <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":47}
[2024-09-10 14:27:14] info: 	zh:zstack:znp: Port closed
[2024-09-10 14:27:14] debug: 	zh:controller: Adapter disconnected
[2024-09-10 14:27:14] info: 	zh:zstack:znp: closing
[2024-09-10 14:27:14] error: 	z2m: Adapter disconnected, stopping
[2024-09-10 14:27:14] debug: 	z2m: Saving state to file /config/zigbee2mqtt/state.json
[2024-09-10 14:27:14] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2024-09-10 14:27:14] info: 	z2m: Disconnecting from MQTT server
[2024-09-10 14:27:14] info: 	z2m: Stopping zigbee-herdsman...
[2024-09-10 14:27:14] debug: 	zh:controller:database: Writing database to '/config/zigbee2mqtt/database.db'
[2024-09-10 14:27:14] info: 	z2m: Stopped zigbee-herdsman
[2024-09-10 14:27:14] info: 	z2m: Stopped Zigbee2MQTT
[22:29:21] INFO: Preparing to start...
[22:29:22] INFO: Socat not enabled
[22:29:22] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-09-10 22:29:24] info: 	z2m: Logging to console, file (filename: log.log)
[2024-09-10 22:29:24] debug: 	z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2024-09-10 22:29:24] info: 	z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
[2024-09-10 22:29:24] info: 	z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-10 22:29:24] debug: 	z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":49307,\"extendedPanID\":[183,13,107,35,111,42,80,92],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0\",\"adapter\":\"zstack\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
[2024-09-10 22:29:24] error: 	zh:zstack:znp: Failed to determine if path is valid: 'Error: ENOENT: no such file or directory, lstat '/dev/serial''
[2024-09-10 22:29:24] debug: 	zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":49307,"extendedPanID":[183,13,107,35,111,42,80,92],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0","adapter":"zstack"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2024-09-10 22:29:24] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-09-10 22:29:24] error: 	z2m: Error while starting zigbee-herdsman
[2024-09-10 22:29:24] error: 	z2m: Failed to start zigbee
[2024-09-10 22:29:24] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-09-10 22:29:24] error: 	z2m: Exiting...
[2024-09-10 22:29:24] error: 	z2m: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0
[22:32:00] INFO: Preparing to start...
[22:32:00] INFO: Socat not enabled
[22:32:00] INFO: Starting Zigbee2MQTT...
[2024-09-10 22:32:01] info: 	z2m: Logging to console, file (filename: log.log)
[2024-09-10 22:32:01] debug: 	z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2024-09-10 22:32:01] info: 	z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
[2024-09-10 22:32:01] info: 	z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-10 22:32:01] debug: 	z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":49307,\"extendedPanID\":[183,13,107,35,111,42,80,92],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"path\":\"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0\",\"adapter\":\"zstack\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
[2024-09-10 22:32:01] error: 	zh:zstack:znp: Failed to determine if path is valid: 'Error: ENOENT: no such file or directory, lstat '/dev/serial''
[2024-09-10 22:32:01] debug: 	zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":49307,"extendedPanID":[183,13,107,35,111,42,80,92],"channelList":[11]},"serialPort":{"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0","adapter":"zstack"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2024-09-10 22:32:01] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0","baudRate":115200,"rtscts":false,"autoOpen":false}
[2024-09-10 22:32:01] error: 	z2m: Error while starting zigbee-herdsman
[2024-09-10 22:32:01] error: 	z2m: Failed to start zigbee
[2024-09-10 22:32:01] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-09-10 22:32:01] error: 	z2m: Exiting...
[2024-09-10 22:32:01] error: 	z2m: Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_4874a65c52a4ed1199ef86582981d5c7-if00-port0
Check if the serial path is still correct.
Yes, seems to be the same settings.
I rebooted and machine rather than just the VM HA and the Zigbee sensor is providing data into HA again.
